Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 11-25-2020, 04:32 PM
Whirl Wind Propellers Whirl Wind Propellers is offline
Default Video of 300 Series Constant Speed Propeller
https://www.youtube.com/watch?v=BI9Ts4pGyag
Check out the 300 series constant speed propeller: the lightest propeller in its class! Get better takeoff performance, higher rate of climb, smoother operation, and no compromise on top speed
Best Applications:
300-72" (36 lb): RV- 4, 6, 7, 8, 9, 14
- Engines: (I)O-320, 360, 390
300-77" (42 lb): RV-10
- Engines: (I)O-540 Straight Valve
Whirl Wind's newest propeller, the 300 series comes in 70-79" diameters ranging from just 36 lb - 42 lb with spinner and hardware included in the weight.
KitPlane Article about the propeller with some performance comparisons: https://www.kitplanes.com/whirl-wind-300/
Propeller on Whirl Wind website: https://whirlwindaviation.com/props/300series.asp
Old 11-26-2020, 07:08 AM
Electrogunner Electrogunner is offline
Default Prop
How do these compare to the 375RV that I have on my 10? They look similar except the tip design, mine is a sharper point.
And BTW I'm super happy with my whirlwind. Everyone comments on how smooth it is.
RV10 N620RV
IO540 C4B5
Whirlwind 375RV prop
Garmin G900X
First Flight 2/14/2019
Old 11-30-2020, 11:00 AM
The HRT375 is about 55 lb compared to the 42 lb for the 300 series 77. Thatís because the HRT propellers use an old McCauley based hub system and the 300 series is an all new Hub platform design. It packages smaller allowing it to be lighter and to fit better in the spinner (no more blade ferrules showing through the spinner blade cutouts). The 300-77 was designed specifically around the RV-10/IO-540 engine airframe combination. PIREPS say the 300 series offers better takeoff and climb performance, smoother operation, and no sacrifice on top speed.
Old 11-30-2020, 12:59 PM
iwannarv iwannarv is offline
Very interested in this prop for RV10. But no data or information on the WW site?
Brad Brensing
RV-10 Emp/Tailcone - Complete, QB Wings - Complete, Fuse - Building, Finish Kit - May '21
Never judge a man by his trim tabs.
Old 11-30-2020, 09:10 PM
N804RV's Avatar
N804RV N804RV is offline
I'm a gonna be needing one of those for my RV-8. Not ready to hang the engine yet. But, hopefully in about 6 months.
I'm wondering how far out should we be ordering? What kind of delivery time? And, What are the terms?
Ken W.
Mount Vernon, WA
2020 VAF Supporter
Old 12-01-2020, 12:09 AM
N546RV's Avatar
N546RV N546RV is offline
I order a 300-72 for my -8 build recently. Quoted lead time on initial contact was 4-6 weeks. In actuality, the prop shipped about 2 weeks after I placed my order; all told, exactly four weeks passed from the time I placed the order to the time I cracked open the crate at home. A $1000 deposit was required to place the order.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
Old 12-01-2020, 12:23 AM
emsvitil's Avatar
emsvitil emsvitil is offline
How does it compare speedwise to the Hartzell F7497 BA?
Ed
Old 12-01-2020, 05:35 AM
RV6_flyer's Avatar
There is an article in January 2021 Kitplanes comparing the new prop against the Hartzell. It is possible that the Hartzell prop is F7496 BA and not the newer F7497A.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 12-01-2020, 06:00 AM
1001001's Avatar
1001001 1001001 is offline
Yes, I wonder why they have no data or pricing for the RV-10 prop. I hope they get that up soon.
Old 12-01-2020, 06:36 AM
Freemasm Freemasm is online now
Default CG issues
Very intriguing. Would love to put one on the F4 (four cylinder rocket) I'm building but I actually will probably need the up-front weight for CG purposes. Won't know for a while if this is a real option for my (or similar) builds.
