Keep VAF
Going
11-24-2020, 05:32 PM
Mattituck TMX IO-540 Question
Would anyone have any specific details on a 2008 TMX IO-540 from Mattituck?
Since they have dissolved the build records have disappeared according to Teledyne Continental.
Just wondering what would be the most similiar configuration of it to a standard build IO-540-????
Thanks.
11-24-2020, 05:43 PM
Senior Curmudgeon
Welcome to VAF
Steve, welcome aboard the good ship VAF
Mahlon might know, he will probably chime in here, if not you can send him a PM.
https://vansairforce.net/community/member.php?u=663
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
11-24-2020, 06:02 PM
What information are you looking for? I have one, but it has been top overhauled with Millenium cylinders and pistons. I have some of the original Mattituck documentation that I got when I bought it from the original owner.
P.S. this one was originally built in 2009.
11-24-2020, 06:31 PM
Hello 1001001,
I guess I have two questions you may be able to help with.
Is there anything from Mattituck that states what the closest build of an IO-540 could be?
It's their Experimental TMXIO-540 but is there a close comparable to all of the versions of the certificated Lycoming IO-540? Maybe Mattituck has something buried in the original build sheet.
Secondly, are you aware of any ADs on the case or lower end?
I guess I'm in the dark on camshaft and crankshaft part numbers for now.
Too bad they didn't make the records available.
11-24-2020, 06:50 PM
Originally Posted by sslayback
Hello 1001001,
Secondly, are you of any ADs on the case or lower end?
Check your cylinders to see if they are the AD category ECI cylinders.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2021
11-24-2020, 06:52 PM
Originally Posted by Mike S
Thanks for the welcome Mike
11-24-2020, 06:55 PM
Thanks...
The top is only a year old and not ECi.
At least thats one major AD that doesn't apply.
11-24-2020, 08:28 PM
VAF Moderator / Line Boy
Well technically speaking, a “TMX” engine is Experimental, it has no TCDS, so it isn’t really possible to have an AD against it. Now there could be AD’s against an extremely similar engine, and those would be good to look at - but if we are cutting regulatory language razor thin, you won’t find any AD’s against the engine.
As pointed out above - Mahlon is probably your best source of info.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
11-24-2020, 08:46 PM
Thanks Paul,
I am just trying to see which build it would compare to and, while of course ADs don't apply, I certainly would like to be aware of any defects that parts may have.
11-24-2020, 08:59 PM
Paul
True,,,it’s experimental so no AD’s apply. But you certainly don’t want those cylinders effected by the AD on your EXP engine.
David C.
Howell, MI
Thread Tools |
Display Modes |
