Old 12-23-2019, 08:01 PM
SRCP2019 SRCP2019 is offline
Exclamation RV-8 Right Rudder Pedal Issue
Hello all
First post here, really enjoying the forum; I learn something new every time I log in. Just picked up my new-to-me RV-8, absolutely love it. Decided to move the ground adjustable rudder pedals a notch aft and discovered that the right rudder pedal attach bolt/cotter pin/castle nut had been rubbing against the bulkhead that divides the footwell from the front baggage area. It had actually gouged an arc about 3? long and 3/4? wide completely through the aluminum into the baggage area.
My thoughts to fix:
1. Turn bolt around and insert from outside, but I?m concerned about snagging the nut and cotter pin on inside of rudder pedal with shoes or boots when using rudder.
2. Cut wider slot in bulkhead around where it was gouged, and fabricate a box to cover cutout and attach to baggage area side.
3. ??
Has anyone else seen this?
Standing by for solutions that should have been obvious to me...
Old 12-23-2019, 10:34 PM
xblueh2o xblueh2o is offline
Without looking at the entire thing I can't make an informed opinion on why but I assume that the bolt you are talking about is an AN23 clevis bolt per the plans. I think you are on the right track that turning that around could create something to grab your shoes so it would be inadvisable. Do you have pictures of the general area?
If it were me, I would figure out why it is happening and correct it. There has to be something about your airframe that is different because there are lots of these aircraft out there that don't have this problem.
The easiest place to start is just comparing your aircraft against the construction drawings. If you don't have the set of drawings you can order them from Vans in an electronic format that is fully searchable for very reasonable cost (like $10 I think).
Once you figure out what the issue is and correct it you can replace the baggage wall with a new one and it will probably cost more to ship it than the part costs.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Old 12-24-2019, 12:53 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default rubbing
When built according to the plans, this clevis bolt is almost touching the baggage panel. If you put anything in the baggage area, this can bulge out just a bit and it will rub.
This panel comes out very easily with a few screws, so you could remove it, build in a small cutout to give space for the bolt.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 12-24-2019, 12:35 PM
SMRacer's Avatar
SMRacer SMRacer is offline
Default Deep well in RV8
I put the smoke tank in my RV8 front deep well. That caused the bulkhead to push out and rub the castle nut/screw on the rudder pedal. I did not notice the wear until it rubbed a hole through the bulkhead and froze the rudder pedal. Noticed just prior to takeoff. This is something all RV8 owners should check.
Jim
Leesburg, VA (KJYO)
RV4 N444JT (sold)
RV8 N37PK
Old 12-24-2019, 12:43 PM
sjhurlbut sjhurlbut is offline
I reversed the bolt on mine. Just be sure the cotter pin doesn't have ability to catch your shoe.
Originally Posted by SRCP2019 View Post
Hello all
My thoughts to fix:
3. ??
Visit and subscribe to Stu's Aircraft Factory on
https://www.youtube.com/channel/UCGQ..._as=subscriber
Steve "Stu"
Cold Lake, Alberta
7A #70015 - C-FZQX - built - sold
7A #71629 - C-FSIS - built - sold across Atlantic
7 #70215 - C-GOJU - flying - sold
7 #70703 - C-GMIY - flying - sold
6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
8 #82842 - C-FSBG - Fastback - built - sold
4 #2723 - C-GVBX- building
Old 12-25-2019, 09:37 PM
Wunderon's Avatar
Wunderon Wunderon is offline
reversed the bolt on mine as well. Could always put shrink wrap over it to reduce the chance to catch something.
Dave Grimmer
RV8 N46LG for Lynda
Flying
Edmonds WA
paid 2019
Old 12-26-2019, 04:57 PM
Thanks everyone, really appreciate all the responses 👍🏻
I have the bulkhead out of the plane now, will look at doing a cutout and a box. Position of interference has changed a bit since I moved the rudder pedals aft a notch, so will need to design cutout so that all 4 possible pedal positions will be free of binding or scraping. I?ll dig into the forum how-to?s and try to post a couple of photos when it?s complete.
Roger
Madeira Beach, FL
RV-8 SN#81144 N408RV
Donated for 2020 - Worth every penny!
Old 12-26-2019, 05:45 PM
cfiidon's Avatar
cfiidon cfiidon is offline
Default Stiffener
Perhaps a stiffener horizontally or diagonally across that point on the baggage area side may help you win the battle of the bulge.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 12-26-2019, 05:56 PM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
I had the same issue at first with mine. If yours is like mine, there is room to put a washer under the head of the bolt which will have the effect of adding 1/16" additional clearance on the thread side of the bolt while still maintaining the necessary clearance for the cotter pin.
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
https://www.marksrv8.com
