Keep VAF
Going
05-23-2016, 10:17 AM
Dynon Servo wiring question
Can someone help shed some light on why the servo wiring schematic shows two female D-Sub connectors? I'm not following why or what there would be two for.
Thanks.
Brant Seghetti
Top Cover Aviation
Nut Tree, CA
P-51, RV-8, 90A, S1
ATP, A&P, IA
Dues Gladly Paid
05-23-2016, 12:34 PM
Unsure what schematic you're looking at. Got a photo or a link?
Kurt W.
RV9A
FLYING!!!
Brant,
We have a lot of wiring diagrams. Where are you seeing this?
05-23-2016, 12:39 PM
Right at the servo you put a female connector and male connector to make a line disconnect before the harness for when you need to remove the servo you just disconnect the Sub Ds and leave the harness, if that is what you are referring to.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
05-23-2016, 12:51 PM
The harness itself has two female connectors. Each end connects to a male DB9. One on the servo, one to the network hub/EFIS.
Ray
05-23-2016, 04:36 PM
Originally Posted by dynonsupport
Brant,
Figure 100 on page 10-10 of the SV installation manual.
Brant Seghetti
Top Cover Aviation
Nut Tree, CA
P-51, RV-8, 90A, S1
ATP, A&P, IA
Dues Gladly Paid
05-23-2016, 05:10 PM
Brant,
The connector at the servo end is there just so you can maintain the servo in case you ever need to remove it. If you want to direct connect the wires you can.
Thread Tools |
Display Modes |
