Dynon EFIS-D10a EMS-10 AP74 HS34 SL30 496 wiring with an eye towards adding a Garmin
Ratdog
Active Member
I'm adding a HS34 and an AP74. I was wondering if anyone has done this combo: Dynon EFIS-D10a EMS-10 AP74 HS34 SL30 496. Thinking of removing the 496 and replacing it with with a GPS175. Will it work with the legacy Dynon stuff? Any diagrams? Thank you!
Ratdog
Email me at [email protected], and will send you some diagrams that will work.
And to answer your question about the GPS175, it will work fine with the old Dynon stuff.
Brian
Same info as Brian, I have D-100, D-120, HS34, SL30, GNX 375 and Aera 760, all works fine. You might want to consider adding the 760 to give you a larger screen for the G 175 display output for charts etc. and for the frequency upload to the SL30, it can also drive the A/P in RS232 mode.
I used some of Brians diagrams (from the Dynon forum) as a starting point, I also decided to get the 375 harness from Stein as the high density connectors seems a bit more challenging than regular DB connectors.
Figs
