Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Autopilots
Old 02-19-2021, 08:43 AM
JackinMichigan's Avatar
JackinMichigan JackinMichigan is offline
Default Autopilot elevator control 'porpoising' quite badly.
I have an entirely Garmin control panel in my RV-10 and one of the features is an autopilot (roll and elevator, no rudder). The roll control works great, but when I engage altitude hold the plane will begin 'porpoising', and it will get exponentially worse till, after three up-down cycles, I have to disengage the autopilot. I've reduced the sensitivity, reaction speeds and reaction forces of the elevator servo but nothing seems to help.
One thing I've noticed is when I'm adjusting elevator trim, the trim indicator lags way behind the actual trim motion. Not sure why that is, but the entire electric trim assembly is buried deep in the tail with no good way to get to it. I suspect this has a lot to do with it.
Jack and Dave Groat, father and son
RV-10 N1861G
Build #41389, started Oct 2012
Current status: 1st Flight 11/10/17
50 hour oil change: 8/29/19
Old 02-19-2021, 08:54 AM
larrynew's Avatar
larrynew larrynew is offline
I used the settings from this post. Now works great.
https://vansairforce.net/community/s...72&postcount=7
Larry New
RV-7A - Built, flew 950+ hrs, sold
RV-10 - Built, flying 250+ hrs
RV-12iS - All kits ordered!
VAF on Annual Autopay
Old 02-19-2021, 09:03 AM
DanBaier's Avatar
DanBaier DanBaier is offline
If the tweaks don't work, you might have a problem with the static source - there can be a reservoir effect with too many gadgets hooked up and then the altitude hold does a lot of hunting and can't keep up. If that turns out to be the case, you'll want to consider a dedicated static line for the autopilot.
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
Old 02-19-2021, 09:35 AM
woxofswa woxofswa is offline
I have Dynon, but have experienced similar symptoms. Sounds to me like your servo shear screw has broken. There can still be some friction on the plate, especially if the screw broke but left a little chunk of itself behind that is scraping on the plate. It works a little bit but loses grip and keeps trying to correct itself.
Myron Nelson
Mesa, AZ
RV-10 N24EV
KITPLANES Contributing Editor
Walt's Avatar
Walt Walt is online now
Disengage auto trim and try it, sounds like maybe the auto trim is running backwards.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 1900+ hrs, New Titan IO-370, Bendix Mags
Old 02-19-2021, 10:11 AM
JTJones's Avatar
JTJones JTJones is offline
Default What Walt said,
or it could also be the pitch servo direction needs to be reversed. I had that problem when testing my autopilot. I had the auto trim off as recommended. Reversed the pitch servo direction and was good to go.
Edit: After thinking about it, it was after activating the auto trim that I had the issue. Reversing the auto trim direction corrected the problem.
Jeffrey T Jones
RV-14 N588TJ Completed
First Flight July 10, 2018
Flight testing completed August 14, 2018
2021 VAF dues paid plus beer money😜
Last edited by JTJones : 02-19-2021 at 03:50 PM. Reason: After thinking about it I need to revise my post.
Old 02-19-2021, 04:41 PM
gfb gfb is offline
It’s not the shear screw, Garmin servos use a clutch.
Go through the calibration routine described in the manual.
Check that all the surfaces are deflecting in the correct directions.
RV-9A - started 01/2015, completed 07/19/2018, 500hrs 03/14/2020
RV-10 - started 04/2020
Old 02-20-2021, 09:26 AM
lr172 lr172 is offline
I agree with trying it without the auto trim to eliminate any issues on that system. On my 10 with G3X, I set up the AP with the recommended settings and found that I needed a good amount of change to the gain on the ptich axis to get it to be stable. Can't remember if it was porpoising or just twitchy. Either way, I ended up with a pitch gain that was quite a ways off from the recommended setting. Mine is rock steady.
Garmin has a very involved regiment for dialing in the AP in an appendix of their manual. Suggest reviewing that.
Larry
Old 03-15-2021, 10:08 AM
Dugaru's Avatar
Dugaru Dugaru is offline
Default Adjusting
Do you have a link? I've got a slight porpoising problem (but only at high altitudes, 10K or so) that I need to troubleshoot. I also overshoot turns a bit.
Larry
N929JA, 2007 RV-9A
Based W96: New Kent International Aerodrome
(near Richmond, VA USA)
2021 Dues Paid
Old 03-15-2021, 10:21 AM
Walt's Avatar
Can be found in the G3X install manual.
