Go Back   VAF Forums > Main > Acts of Charity (using your RV)
Old 07-11-2011, 11:27 AM
tkatc's Avatar
tkatc tkatc is offline
Default New to Pilots and Paws...info request.
I just signed up and volunteered for the pilots and paws program. I had always had this sort of thing in the back of my mind before buying my RV. Now I can act but I want to be as prepared as possible.
Anybody have any pictures showing what sort of crates or harnesses that are suitable to a slider RV-7A? Basically what I need is info on how to configure the airplane for a safe and comforable transport. I do not know what size crate would fit the front seat and or rear baggage area. What type of crates are best? Are there "soft" crates vs hard crates? And where can these be obtained?
Track my RV7A!!
Bought my flying -7A
Building an -8! (Fuse)
Old 07-11-2011, 12:09 PM
bkthomps bkthomps is offline
Their website is horrible, caps lock in rampant use, most of the transport requests are halfway across the country. They really need some modern logistics professionals and marketing/communication people in there to do that site justice
Old 07-11-2011, 12:43 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Last year I had two free crates sent to me by the Paws organizers.
As for crate size...get a tape measure. Originally I wanted to slide an intact crate under the cross bar behind the seat. That did not work so I had to put the crate together in the back.
I remove the passenger seat and place a crate there or one on top of another.
While soft crates are available that seem great, disinfecting them for parvo may be problematic.
Pictures here may help:
http://www.vansairforce.com/communit...ad.php?t=63279
Old 07-11-2011, 01:06 PM
tkatc's Avatar
Thanks Ron! I saw those posts and it kind of scared me. that beige crate looks like a MONSTER.
I think a large crate, that would fit in the baggage area, and also was split in 2 halves, upper and lower would be ideal. Just throw the lower half in, the pile on the pooches, then secure with the upper half. I didn't know if these organizers had solutions or not...I'm now guessing not. I also don't have a problem with a bit of foam padding and a blanket covering the baggage area and/or the passenger area with seat and stick removed so long as the "beast" was harnessed in some fashion to prevent disruption to a safe flight.
I was sort of hoping that someone would say..."Go to Petsmart and get ABC crate, it will fit easily in the baggage area in 2 halves, and perhaps get the DEF crate for the passanger area"
Any horror stories? vomitting? terrified pups? or worse, an in-flight death?
Track my RV7A!!
Old 07-11-2011, 01:37 PM
Ron Lee's Avatar
Suggestion: Whatever crate you use in the back...put it together before you start. Yes that may mean putting it together bottom first..then top at home. You face the door towards where you will load and insert the dog or dogs.
I will go measure mine soon so you have a starting point.
The beige one you see in one picture is gone.
I also bought several large white towels from Walmart to place under, in and around crates to contain accidents. They get a bleach solution wash after use to control possible parvo (see PnP discussion).
These white towels are also use to cover crates to help control heat (keep the sun off).
Lab Air has a perfect safety record.
I was vomited on once. Hint....if you carry a small pup on your lap (not recommending it)....have things protected by a towel or acceptable equivalent.
My largest crate is about 17" wide, 25" long (door on one end) and 16" high. Since I wanted to have it put together and slide under the cross bar behind the seats, that limited the height. Perhaps plan on putting one together in the cargo area and see if you can get a larger crate. To me...volume is essential.
It is a Pet Taxi (not sure what size but their website may show it).
Here is the PnP discussion on getting free crates, harnesses, leashes.
http://pilotsnpaws.org/forum/viewtopic.php?f=3&t=3847
Here is another discussion of how I transported eight pups.
http://www.vansairforce.com/communit...ad.php?t=61026
I do not intend to be cruel to any pups but I will tolerate less than first class conditions (more than one pup in a crate) if it saves them. Three hours or so snuggled together like they probably do anyway is a small "discomfort."
Old 07-11-2011, 01:42 PM
Default Ask Brutus
You better ask Brutus what he thinks. If he can walk kids he could tell you what harness or cage fits them . BTW did you fly with him in that new thingy?
Old 07-11-2011, 01:46 PM
pierre smith's Avatar
Default Your local newspaper.
Our newspaper office gave me bundles of unsold newspapers to line the floor of my -10 and I then put plastic sheet over that...might have been the other way around.
You may also limit your rescue flights to smaller dogs, so you can have two crates in the front seat, on top of each other.
Best,
Rv10 Sold
46 years ag pilot/CFI
Air Tractor 502/PT-6
Building RV-12, Wings, fuse, emp complete. FWF in progress.
Old 07-11-2011, 02:32 PM
tkatc's Avatar
Vlad,
Brutus flies just fine with his harness!! I will want to get him MuttMuffs for extended or more frequent flights though.
Track my RV7A!!
Old 07-11-2011, 02:39 PM
mikegraycmg's Avatar
mikegraycmg mikegraycmg is offline
Default Bonanza
When I do this in my Bonanza, I just secure the dog with a harness to one of the rear seat belts. Usually, they go right to sleep. It's too hard for me to get a crate into the plane.
Mike Gray, A&P IA, AET, KGPM, Grand Prairie, Texas
1956 Bonanza for sale.
Old 07-11-2011, 06:29 PM
tkatc's Avatar
Ok, this is happening quite quickly for me. I have been contacted about a flight this Sunday and will accomadate if I can. I prefer crates because you never know if the dogs will freak out or "leak" out. I could go with just a harness but the current mission would be 3 dogs, 2 in back and 1 in front. Of course this is dependent on if the dogs will play nice with each other since I cannot get a crate large enough for the 2 dogs in the rear. The dog in the front will be crated.
The crate sizes I think will work are rather small....seems like any dog(s) in the rear will have to be harnessed instead unless they are just pups.
Track my RV7A!!
