Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
Old 01-20-2020, 06:07 PM
rjcthree's Avatar
rjcthree rjcthree is offline
Default Facing a D3000 OH, any new replacement rumors?
I’m facing a five year D3000 dual mag OH. Are there any new rumors of a dual mag direct replacement, or even an available single EI mag so I can go stand alone on the second? I don’t plan on going to a dual battery setup on this A/C. Google gives me nothing but the 2018 hybrid articles.
Rick
RV-9A N183RC/90432: tip-up, O320H2, Ellison, Dynon D180, CPi2, Sen GA, at KLPR
RV-8 83718, wing kit, tanks done, with a four year plus plan - on hold due to home move
2011-2021 VAF contributor
Old 01-20-2020, 08:56 PM
Toobuilder's Avatar
Throw a conventional magneto in the hole on the accessory case and do the crank triggered CPI for the other plugs.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 01-20-2020, 09:07 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Search the archives for a how-to on installing a single mag. It's a certain Bendix mag required.
Old 01-20-2020, 10:18 PM
lr172 lr172 is offline
+1
This is what I would do. Unsure if a single mag can go in that hole though, as I have no experience with those dual mags.
Larry
Old 01-20-2020, 11:29 PM
hgerhardt's Avatar
Originally Posted by lr172 View Post
....Unsure if a single mag can go in that hole though, as I have no experience with those dual mags.
Larry
Again, read the archives. It's been done several times just on VAF.
Old 01-21-2020, 01:27 PM
The SDS ignition system has their own backup battery available (small and compact). You could replace with a dual SDS system and be done with Mags all together.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 01-21-2020, 02:37 PM
WillG WillG is offline
See airtractor8 post - 12-30-2018
H2AD mag
Old 01-21-2020, 06:24 PM
Caveman's Avatar
Caveman Caveman is offline
Originally Posted by rjcthree View Post
I?m facing a five year D3000 dual mag OH. Are there any new rumors of a dual mag direct replacement, or even an available single EI mag so I can go stand alone on the second? I don?t plan on going to a dual battery setup on this A/C. Google gives me nothing but the 2018 hybrid articles.
Some info in the following thread:
http://www.vansairforce.com/communit...ad.php?t=90425
Joe Schneider
RV-7, IO-360, BA Hartzell, N847CR
Flying since 2008
Old 01-21-2020, 06:58 PM
cardinalflier cardinalflier is offline
Install the SDS CPI-2 system. You will love it. I? ve been running the SDS on my 6 for 7 months. It is great with superb support by Ross. Bruce Estes
Old 01-21-2020, 08:14 PM
rjcthree's Avatar
Default Frankenmag?
I copied a section of Tractor8?s post below. I commend him for his research and thoroughness in his description.
<start quote> To do this you can just use the old D2000/3000 and permanently ground one side.(you may already have this setup?) OR use a single Bendix 1200 series mag in its place. The impulse coupling variety has the same drive dimensions as the old dual mag but must be setup to turn in the right hand direction.(most of them are left hand rotation but can be easily changed to Right hand). Try part# S4RN-1227 10-349365-6
You will not however be able to use an impulse coupling with this setup ( there is none available with the required amount of Lag in the right hand direction that will suit the 1200 series). You will need to use a drive coupling commonly used on 6 cylinder 1200 series setups with retard breakers. Part # AEL 73000. This coupling uses the same drive cushions and arrangement as the D2000/3000 and will work with the drive gear in the engine.
You have to use the Electronic ignition for starting and will have to setup your ignition switch(s) to ground the mag for starting or you will get kickback if the mag fires at low speed.<end quote>
I personally don?t feel great about the frankenmag setup. Oddly, I feel fine with a megajolt/EDIS4, maybe because I have had one running on the bench for a while. I guess my goal or wish list is a self contained emag to plug the hole for one side, and a stand alone for the other. Plan b is to ground one side of the D3000 as suggested and Stand alone the other side. I don?t have a lot of under/beh8nd panel room (don?t install the glove box!) for much more after the ADS-B install.
Rick
