Keep VAF
Going
12-15-2015, 07:52 AM
Need Cylinder Shop Recommendation
Engine is a 1000 hour Mattituck TMXO-360 in a 2005 RV7a. Runs fine, compression tests fine. Issue is high oil consumption at 1 Qt every 3.5 hours. We have verified it is not leaking and that it is not being blown out. No metal in the oil filter and it does not foul plugs. So the assumption is it is being burned in combustion.
Looking to pull the cylinders and send them out to a knowledgeable shop that will give us an honest assessment and a reasonable repair. Plane is in NC so the southeast would be great but not essential.
Please recommend any shops that specialize in this type of work where you have had good experiences. As always, stories of your experiences are appreciated.
Bill Fearheiley
Lake Norman, NC (14A)
RV7a N705RP (no longer own)
Contribution in for 2017, money well spent
12-15-2015, 08:36 AM
Oil burn
If you fill the crankcase to the full mark it will throw out the first two quarts quickly. If you run it at 6 quarts it will not. I don't add a quart until it is down to 5 quarts.
Horse Power is good, more is better and
Too Much is Just Right
RV 8 Super charged Barrett IO-390
Dues paid 2020
Dan "Nordo" West
12-15-2015, 08:56 AM
yes, we keep it between 5 and 6 quarts, no more.
Bill Fearheiley
12-15-2015, 09:58 AM
Super Moderator
Graham
I used Graham aircraft engines in Newnan Georgia to do mine. I just had the same problem with a 930 hours Mattituck Red Gold IO-540. I put on 6 new Superior Millenium cylinders and had Graham ring them for me.
Vic
 Vic Syracuse
www.Baselegaviation.com
12-15-2015, 10:22 AM
I had nearly identical symptoms on my IO-540. Took it to Zephyr Aircraft Engines in Zephyrhills, FL. Their reputation is excellent and I have been very pleased. I now have 11 hours on new cylinders and oil consumption is just about nil. Fast service and very reasonable pricing. Call them at 813-788-3305 and ask for L.J., the shop manager.
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2021
"In '69 I was 21, and I called the road my own"
Jackson Browne
12-15-2015, 11:06 AM
VAF Moderator / Line Boy
You didn't mention what brand cylinders are on the engine, or the cylinder finish. My Mattituck built in that era was all ECI components, including Cerminil Cylinders. ECI has a problem with the rings used with Cerminil delaminating, and that produced exactly the symptoms you are seeing. The Cerminil is tricky to hone, because it is so hard, and many shops wouldn't touch them. I was unaware of the ring issue and when I called ECI I told them what was going on, and asked about how to hone and re-ring the cylinders, thinking they were just glazed. I essentially got no help at all, except that they could recondition the cylinders for a price not much less than what a new Lycoming Nitrided stud assembly would cost from A.E.R.O. - so I bought four new jugs and put these on the shelf.
I later talked with an ECI VP (this was a few years ago) at SnF, and was told that they certainly would have taken care of me because they knew about the ring issues - I had to thank him for nothing, because by then, I'd already been flying with the Lycoming cylinders.
Bottom line - if you have Cerminil, you might call ECI directly and see if they will help you out.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
12-15-2015, 11:08 AM
My only recommendation is that you do not use Triad Aviation in Burlington. You can PM me for details but they returned some cylinders to service that never should have been.
12-16-2015, 04:15 PM
Thanks for the inputs
please keep them coming.
Bill Fearheiley
12-16-2015, 06:23 PM
"It's easy to be generous when it don't cost you nothin." Archie Bunker
Paul, just a curiosity, did you find out what type of rings the are? Plasma faced, or chrome plated? I was it both the oil and compression rings?
Either will stick and basically gall but plasma will go to higher temps before softening.
Bill
RV-7
Lord Kelvin:
12-16-2015, 06:32 PM
I believe it was the plasma-coated rings, and they were delaminating - a bad process or batch. ECI figured it out, but didn't have a way to get the word out other than blasting it to all forums and publications (which they didn't try - and admittedly, that is tough), so it was folks finding out when they had a problem. They put it on their web site - but didn't have a way to notify owners to check that. That is, admittedly, one of the problems we face (with our manufacturer friends) in the experimental world. There is no AD process, so word doesn't get out easily.
Paul
Paul F. Dye
Thread Tools |
Display Modes |
