  #21
Old 08-04-2015, 10:20 PM
AX-O's Avatar
AX-O AX-O is offline
Do you know if he still had trouble after he did the switch? Or if his problem was fixed?
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 08-06-2015, 02:51 PM
fstringham1 fstringham1 is offline
Default RE:fix
Hi Axel
Sadly N74BZ was sold Jan 2013. It now is owned by a wonderful individual and retired Air Force pilot in North Carolina.
New larger oil cooler really helped subdue the ECi oil squirter high oil temp enduced problem. I do believe that Allen's cowl flaps would have also helped. I did increase the exit air by cutting back the bottom of the cowl aft 1 to 2 inches also. Not sure if that also was helpful......???? Two plus years without my log is a bummer to rebuild my memory.
Anyway I sure miss the RV flying and hanging with the airport usual suspect all the time. I will be helping a good friend and F1 Rocket pilot build a Carbon Cub EX.
Old 08-06-2015, 04:42 PM
g zero g zero is offline
Default Oil temp
Axo ,
I installed a 17 row cooler , can email pics if you like . Feel free to post them .
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
Old 08-06-2015, 05:27 PM
BillFear BillFear is offline
Default It worked for us
Axel, we installed the AeroClassic clone and it solved our problem with oil temp. Rarely see anything over 200 on oil temp now. Weak link is now CHTs, installed one cowl flap that helped, will probably put in 2nd one at next CI. PM if I can provide any details.
Bill Fearheiley
Lake Norman, NC (14A)
RV7a N705RP (no longer own)
Contribution in for 2017, money well spent
Old 08-06-2015, 07:29 PM
AX-O's Avatar
thank you all.
Axel
