  #21
Old 03-28-2018, 09:09 PM
Kellym Kellym is offline
Originally Posted by SabreFlyr View Post
Offhand, Dan, I'd guess "yes." The internal stop would be nylon against the heavier gauge aluminum rudder spar whereas the standard stop is heavier gauge aluminum against the lighter gauge aluminum skin. Granted, I believe the contact is where the skin is backed by a rib but the internal stop is contacting heavier gauge that is also backed by heavier gauge.
I don't recall where I got my internal stop, but it is made of UHMW plastic, not nylon. Just looked at it yesterday as part of my condition inspection. Some light marking at contact points, but no physical change.
Kelly McMullen
A&P/IA
EAA Tech Counselor
KCHD
RV-10 40866
Old 03-28-2018, 09:42 PM
az_gila's Avatar
az_gila az_gila is offline
Question
Flyboy Accessories maybe?
https://www.flyboyaccessories.com/In...top-p/2102.htm
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-07-2018, 07:59 PM
Flandy10 Flandy10 is offline
Default Back in the Air
Its been a month and a half since the condition was signed off, but I've finally got the post condition gremlins solved.
1- The moving clamp fix required a modification to the intercooler inlets and one of the induction pipes
The top pipe is the new version-a "slightly" more aggressive grip range.
2- RPM sensor replaced and it's reading is now very stable.
3- Oil Temp sensor connection replaced and know works good-no more 350F readings.
4- G3X EMS intermittent because of a loose CAN bus shield solder joint.
So after two short test flights to verify everything was good, it was time to stretch her wings. Left KFFC early morning May 3 nonstop to KAVO (Avon Park,FL) for a freight drop to mom. Left there after a short stay for a quick flight to X35 to top the tanks ($2.89/gal) and then back to Falcon.
Started the day with 43 gallons. Took on 56.3 at Marion County and arrived back at Falcon Field with 58 Gallons remaining.
Total burn--approx. 41 gal.
Hobbs time--5.7 hrs
TAS 155Kts
Distance 760nm
Scott Flandermeyer
Rv-10 TDI 330 hrs
Fayettevile, GA
2021 VAF Donation complete
Old 07-28-2020, 01:50 PM
gfb gfb is offline
Sorry to revive this older thread, but how did CI #2 & #3 go?
RV-9A - started 01/2015, completed 07/19/2018, 500hrs 03/14/2020
RV-10 - started 04/2020
