Old 05-30-2021, 06:04 AM
Blizzard Blizzard is offline
Default RV-10 Forward Side Skin Riveting
Finishing up Section 29 riveting forward side skins. There are 2 rivets at the most forward end of the forward fuselage longeron on each side that I can't get any bucking bar I have to fit. Even the modified elevator bar doesn't fit. There is a gusset there that is causing the tight fit. Looking for a solution.
Tempted to use a blind rivet for those two and fill later. Thanks
RV-10 In-Process
PA-18-150
Airbus A300
2021 Dues Paid
Old 05-30-2021, 07:08 AM
rleffler's Avatar
rleffler rleffler is offline
I don’t remember those as problematic, but would have been at least ten years ago whenI riveted those. My tungsten bar was smaller than the traditional steel bars. I also purchased a variety of bars over the course of the build, several of which I modified.
I wouldn’t use a blind rivet. They will be visible if you do. My advice would be to purchase or make a bar that will get the job done.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 05-31-2021, 07:23 AM
rvanstory's Avatar
rvanstory rvanstory is offline
I used two blind rivets in that spot on mine. 2 things to watch for...
1) Make sure to get "structural" rivets that will have the shear strength needed.
2) Make sure to get ones long enough to give adequate shoulder on back side.
If I remember right, these are 3/32nd holes. I ended up putting a 1/8 rivet in to meet strength and length needs. They sat "very slightly" proud, but a little filler before paint took care of that.
Randy Vanstory
Flying RV10 - N783V
2021 Sun N Fun Reserve Grand Champion
2021 Oshkosh Bronze Lindy
1st Flight 08/20/2020
Donation Happily Made 2021
Old 05-31-2021, 07:35 AM
catcrew catcrew is offline
I probably spent more time on those two rivets than the rest of that skin! I would try something and fail probably 10 times or more.
My final solution was not pretty but it worked. I used a piece of 1/2" square steel I had in the shop that I laid into the channel. I then placed a regular bucking bar against that with some finger tip pressure on the forward end. I then did my best to be in three places at once while squeezing the gun and contorting my hand to hold onto my contraption inside the channel. I way have used some foam wedges to help hold it into place until the pounding started as well. The tough part was that the steel was not dense enough so it took multiple times to get setup, squeeze, the whole contraption fell apart, and reset.
Parish Moffitt
RV-10, Emp complete less fibreglass work, wings completed less the tips, fuselage in progress
www.facebook.com/n17jp
Charlotte, NC
2020 VAF Dues Paid
Old 05-31-2021, 08:39 AM
Chris7 Chris7 is offline
I also used a piece of steel with a heavy bucking bar behind it. Had someone else operate the gun and it worked fine.
Chris
RV-10.
Emp complete (minus fiberglass)
Wings started
First RV-10 build in Hong Kong
Donation made 2020
Old 05-31-2021, 11:09 AM
mturnerb mturnerb is offline
Roger that.
Call me ornery but I've never fully understood the need to drive rivets in every hole, when / where a blind rivet might work just as well. They're easy to fill in and I haven't found them to be cosmetically objectionable. And what if the driven rivet is imperfect? (more likely when improvising a bucking bar) Drilling them out usually leads to "even less" perfect results.
Not to mention the time spent. If there is adequate grip range, I'm going with the blind rivet without a second thought. Or even better - make a 1/8 rivet work and go with CherryMax.
Turner Billingsley
RV-14A built/sold N14VB
RV-12iS in progress as of October 2020
Old 05-31-2021, 08:44 PM
Thanks everyone that commented. Glad I'm not the only one that struggled with these 4 rivets. I eventually ground down the long bucking bar until it fit in that space and made it work. I'm really glad I'm just about done with Section 29!
RV-10 In-Process
PA-18-150
Airbus A300
2021 Dues Paid
