Old 10-28-2017, 07:46 PM
pilot28906 pilot28906 is offline
Default Engine Mount Bolt Torqued?
I installed the engine mount today on the 7 and it went surprisingly well. The question I have is what torque do the castellated nuts get? Also what have others used as shims for the bottom center bolts?
Thank you.
John Johnson
Murphy, NC
RV7
Old 10-28-2017, 09:11 PM
IIRC, one of my shims was a disc of 1/8" stock. Can't remember if the other spot has a thin sheet, or nothing.
Charlie
Old 10-28-2017, 09:27 PM
tgmillso tgmillso is offline
The nuts are torqued to 160-190in lb. you will need to vary your washer stack up to get the right bolt torque and have the cotter pins align. I just used some appropriately thick alclad sheet to make my spacer for the bottom two mount locations. They were later sealed around with fire barrier 2000+ so it is water tight and poses no intermetalic corrosion risk.
Tom.
Old 10-28-2017, 09:47 PM
Robin8er Robin8er is offline
I just used two washers for mine. Hopefully the engine doesn't fall off.
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
Old 10-28-2017, 10:06 PM
gasman gasman is offline
Put a couple hundred hours on the plane and then go back and check the torque on those motor mount bolts.
VAF #897 Warren Moretti
2021 =VAF= Dues PAID
Old 10-30-2017, 10:58 AM
Thanks for the information all!
John Johnson
Murphy, NC
RV7
Old 10-30-2017, 12:36 PM
Jrskygod Jrskygod is offline
Can someone explain why castellated nuts are used in this application? There is no rotational movement. Why aren't metal locking nuts used here?
PS: checked mine today and 3 of 4 were not tight enough.
RV-3 Rebuilding
RV-9 Flying and having fun, experimenting and having fun, did I mention flying and having fun?
RV-6A SOLD
Maule M5-235C SOLD
C-172G SOLD
Stinson L5 SOLD
Grumman AA1A SOLD
