Old 12-21-2017, 02:52 PM
dwranda dwranda is offline
Default Pitot install critique please!
Hello all, wanted to get opinions if my Dynon heated pitot install looks good before I carry on. I wanted to get this done before riveting the outer lower skins. Wiring isn't done yet but that's just a matter of installing a connector on the 3 power wires. I was going to use a molex connector for that but I don't have one. I do have molex pins though. Is it OK to use the pins without the plastic connector part and use heat shrink tube over each wire to hold the pins and wires together? I thought I read that on VAF somewhere. It's not like I'm going to take that connection apart frequently.
[IMG][/IMG]
[IMG][/IMG]
9A in progress
Working on final 90%!!
Mattituck TMXIO-360 red gold
Dues paid May 2022
Old 12-21-2017, 04:03 PM
RV7A Flyer's Avatar
If there's no reason *not* to use a connector housing, then you should use one (one reason being space constraints, or the like, such as for an electric elevator trim bundle). You have gobs of space here, so I'd say "do it right...use a Molex housing". Not a big fan of Molex, but given the current, it's what I used, also.
Heat shrink alone can chafe if not very properly secured, as well...and then you may have pins shorting to each other.
Old 12-21-2017, 05:06 PM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
Why not just use a blue butt splice? Remember your wires will be carrying upwards of 20 amps at times, I think a butt splice is the appropriate way to go here. Leave a nice long service loop and you'll never have to cut off the butt splices.
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Builder & Avionics Installer)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com (Photography)
Track Me
Old 12-21-2017, 05:28 PM
Paul K Paul K is offline
Just make sure every connection can be reached with two hands after the skins are installed! Real pain trying to tighten a fitting or connecting a plug with one hand, blind!
Paul K
West Michigan
2021 donation made, exempt but worth every dime!
Old 12-21-2017, 06:46 PM
Captain Avgas Captain Avgas is offline
It's time for you start buying some connectors and pins. Shortly you're going to need lots of them. Buy a range of Molex connectors. They're dirt cheap.
Go to SteinAir. They stock the lot. Also get male and female pins in light and heavy gauge. And buy a SAT 1023 pin extraction tool. Believe me you'll need it.
And of course you'll need a proper crimping tool if you don't already have one. SteinAir have the lot. Go here:
http://www.steinair.com/product-category/connectors/
Bob Barrow
RV7A
Old 12-21-2017, 07:07 PM
catmandu's Avatar
catmandu catmandu is offline
What Paul said. Nice mounting of the aluminum tubing prior to the connection to the nylon, but think about removing the pitot. On my bought airplane, the pitot had 'service loops' in the nylon tubing as well as the wiring. I was very grateful for that when I needed to remove the heated pitot, which was at least three times in the three years before I replaced it with an AOA inclusive mast. Four mounting screws and a little twisting and out it came through the access plate hole by the bell crank.
Mike C.
Sierra Nevada
RV-6A bought flying (for sale soon)
Super-8 bought flying
Old 12-21-2017, 07:18 PM
waterboy2110 waterboy2110 is offline
Not sure what kind of access you'll have once the skins are on. I only have one access cover for this area. The pitot is going to go in last so even the bends in the aluminum line are going to be a problem. The adels look nice but unless you can get both hands in there it looks like it's going to be a real problem. Also, make sure you're backing that mast up with a doubler. The kit should have included it.
http://jimsrv.blogspot.com
PP - ASEL
Instrument Rating
A&P/IA Rotax iRMT 9 Series Maintenance
EAA Technical Counselor
RV12 Flying.
Old 12-21-2017, 08:51 PM
old pete's Avatar
old pete old pete is offline
all I will say is this. take your time and do it right. if not it can and will come back and bite you later on. wiring is the one thing that can cause all sorts of problems. if you take your time and do it right the first time you will have less of a chance of problems down the road. and as for butt splices I cant stand them. if your building and airplane build it right and that goes for the electrical system as well. I worked for Boeing as a aircraft test tech and fixed wiring issues all the time. it takes just a little more time to do it right. and you will not see butt splices in their wiring.
I have seen wiring done with butt splices and its a mess.
if I was buying a plane and saw the wiring that had load caring wires that had butt splices I would walk away.
do it right the first time and you will make life easier on yourself if and when you have to work on it.
just my 2 cents take it for what its worth.
James Longstreet
little toot biplane built and flew for 10yr-Sold
Bearhawk- project - Sold
RV-7 - Tail kit
skybolt-project
Old 12-21-2017, 10:40 PM
sf3543 sf3543 is offline
Cleco the skin on and see if you can take it apart and reassemble it again.
Make believe you are on your back on the floor and reaching up into the wing.
Steve Formhals
A&P, Tech Counselor & Flight Advisor
Multiple RV builder currently flying
RV3B & Legend Cub
Old 12-22-2017, 02:11 AM
f14av8r's Avatar
f14av8r f14av8r is offline
Default Max Current for heated Dynon Probe
Pat's got a lot more experience than me but I've never seen my heated Dynon AOA/Pitot probe draw more than eight (8) amps.
Randy King
Tampa (Wimauma), Florida
RV-4 N212CS (sold)
RV-8 N184RK (sold)
Currently flying a Pitts S-2E
Exempt and gladly donating anyway - Current through March 2025
