I am planning on the IO-360M1B horizontal induction engine w/ constant speed prop on the 8 I am building. As part of the build process I ordered the throttle, mixture and C/S control cables prior to getting the entire FWF kit. I have since aquired the latest parts list for the FWF kit from Vans and have a delema. I order previously and installed 2 CT Q-60 cables and 1 CT Q-55 cable...I note that the current parts list shows 1 CT Q-60 cable and 2 CT Q-55 cables...is the extra 5 inches of length in one control cable going to be an issue? Should I pull the bad boy and replace?...anyone run into this before in horizontal induction?
