Old 11-11-2020, 09:51 AM
JurgenRoeland JurgenRoeland is offline
Default Sliding canopy worries...
I trimmed most of what needed to be trimmed and I feel like I'm ready to make "the big cut".
The rear bow fits really nicely using all he clamps, the center rear of the plexy needed only little encouragment to fit on the rear part of the center bar.
The rest of the center bar butts nicely in the plexi bubble without using any force.
On the front bow, I used a long bolt to pull the canopy latch tube in 5/8 hole in the canopy.
When I look from the front, there are some serious gaps when I clamp the side bows. The images illustrate my problem. On the right side in the picture, I can almost halfway put my index finger underneath.
I tried moving the frame around but couldn't find get a better match without creating big gaps under the top center bow.
I assume that once the canopy is split, it will be more flexible to comply with the front bow when I clamp it in place then it is now.
I have drawn a 3/32 line for the division with the frame being in the current state.
What I'm worrying about is the movement of the sides when you pull it in on the top. will I still get 1/16 to 3/32 spacing if the whole thing moves, that is the big question.In other words, can I trust my current 3/32 split line .
Before making the cut I thought I'd ask for some opinions here.
Here are some images to illustrate:
http://jursairplanefactory.com/image...111_152620.jpg
http://jursairplanefactory.com/image...111_152611.jpg
thanks in advance
Jurgen
Jurgen Roeland
RV7 builder Belgium
www.jursairplanefactory.com
Old 11-11-2020, 10:15 AM
elev666 elev666 is offline
Default Same here
Hello Jurgen
I have the same problem here and I plan on stress relieving it like others locally have done to try and let The plastic relax on the frame once it is cut, This procedure came from the manufacturer of the plexiglass canopies down in Ohio, may be best to call Van’s and get their phone #
I have modified my finish kit box to become an oven to Slowly take the frame and trimmed canopy up to around 180* Fahrenheit and slowly bring it back down , this has worked for them and only needs a few nylon shims placed underneath the problem areas that remain ,
Good luck , Garry
RV 6. GARV
1946 C85 J3
RV 7 A project
Grounds keeper @ CKS9, 2020 dues gladly pd
Old 11-11-2020, 11:43 AM
mburch's Avatar
mburch mburch is offline
Jurgen - This looks just like what I saw with my canopy, so I think you will be okay. If you have a good fit everywhere except along the front of the sliding canopy frame, it should lay down and conform to the frame shape after you make the big cut. I was surprised by how much it relaxed after separating the two halves. Good luck! The big cut is an exciting milestone in the project.
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 11-11-2020, 12:03 PM
JoopSJ's Avatar
JoopSJ JoopSJ is offline
Fully agree with the above.
Feel free to visit my place in The Netherlands if you want to see my project.
I just glued to main canopy.
Empennage, Wings, Fuse .. Done
Working on Finishing and FWF
Donation 2017. . . 2020
Chairman NVAV (EAA chapter 664 - Dutch experimental aircrafts builders)
Member EAA
Member AOPA
Old 11-11-2020, 01:51 PM
motodave motodave is offline
Also in agreement, once you cut the windshield off the main canopy conforms to the frame nicely.... I did all my work including the Sika bonding my basement shop at about 68-70 degrees, I did not "add" any heat. Check my Flickr page for my photos.
Dave
RV7 Slider N732DH reserved
Empennage 100% Complete
Slow build Fuselage 95% done
Wiring .2% done
Then QB Wings
Littleton, CO
Photo log: https://www.flickr.com/gp/daves_photo_log/79v20C
Old 11-11-2020, 01:57 PM
PilotjohnS PilotjohnS is offline
Default Is Flange On
It looks like you still might have the flange on around the outside. If so, I would suggest you cut that off and the try and refit. With the flange gone and the big cut done, my canopy had no trouble flexing to meet the bows.
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2021, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Finishing Kit 35% canopy done for now
Electrical 65% in work
Firewall Forward 5% in work
Fiberglass 0%, thought i was building in metal?
www.pilotjohnsrv9.blogspot.com
Old 11-11-2020, 02:45 PM
I was hesitating to have the side trimmed down as it's not very clear how much you can go down to still have enough plexi left to the rear sides of the windscreen section. I wanted to go as low as the bottom of the side bows but not sure if that is not too low on the windscreen side.
Jurgen Roeland
RV7 builder Belgium
Old 11-11-2020, 03:14 PM
wirejock's Avatar
wirejock wirejock is offline
Default Cut and trim
Not to sound condescending, but if the hole for the latch has been drilled, you're committed to the current position. Make the big cut and trim the sides per plan. It will be fine. The sides don't overlap the bow frame. If you do, the plexi will be wider than the fuse. There is a cutaway drawing showing the parts and location of the side edge of the plexi. It's accurate.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Disclaimer
Old 11-11-2020, 05:16 PM
Default In addition
Also, you need to decide how the plexi attaches to the side bows. With sikaflex, you can either us a big bead, or the side bow attach metal pieces. This makes a difference on the side trimming position. I just used a large sikaex bead and my canopy is kissing the side bows. I thought i would have 1/4” clearance but when the sika was dry, that gap disappeared.
John S
RV9A- Status:
Tail 98% done
Wings 98% done
Old 11-12-2020, 02:02 AM
"The sides don't overlap the bow frame"
on the reply of Larry :
You mentioned a cutaway drawing, on which plan can I find this or is it somthing from the vans site ?
I understood the drawing on the plan for the side bows and how the plexi attaches there. I was more worried about the depth of cutting the front side where windshield is. I couldn't find a clear indication in the plans how low the plexi comes on the side curves of the front top fuselage skin.
The plexi has these three lines in which I assume are what they refer to as the molding marks. I guess I would be safe cutting until the bottom line of that (when the canopy is laying upside down)
on the reply of PilotJohnS :
I'm going the rivet way as in the plans.
Jurgen Roeland
RV7 builder Belgium
