Old 06-03-2013, 04:02 PM
paul330 paul330 is offline
I suppose it's all a matter of weight, expense and complexity which mitigates against a constant speed prop. I guess it is like the glass/steam cockpit argument but I wouldn't pass by the extra efficiencies and benefits of a CS prop. It certainly would have negated some of the issues you have seen. Of course, it may have thrown up other problems........
I'm building a -10 so won't be doing aeros but that would seem to me to be an extra good reason for a CS prop. In the meantime, I am flying Warriors and Arrows with a club. I find the CS prop in the Arrow makes the aircraft much more stable in speed in cruise apart from any other benefits.
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
2019 Donation Made
Old 06-04-2013, 10:29 AM
bkthomps bkthomps is offline
Originally Posted by Flyguytki View Post
CHT's were reading 1250-1300 and EGTS were right at 410-420 while cruising laps around the airport at 160kts.
oops looks like your brain swapped these
Old 06-04-2013, 11:54 AM
Flyguytki's Avatar
Flyguytki Flyguytki is offline
It sure did, I took it out again yesterday and flew another hour over the airport, the temps are reading much better already. At full throttle and mixture at 3200 ft, cylinders 3 and 4 are both reading 365 and 1 and 2 are reading 380. I think with some modification to the air Dams on 1 and 2 I can bring them all down within a few degrees of each other.
I'm not to happy with the Propeller however, It is a fantastic Cruise prop, once you hit 125kts it will accellerate like you wouldent believe however getting to 125kts takes to long in my eyes. I am going to talk with Craig today and see what we can do to maybe loose a few MPH on the top end but gain it in acceleration and climb.
Overall however, it is a fantastic airplane, simply amazing with what you can do with it.
RV-7 N87DX Built, Flown, and Sold!
Old 06-04-2013, 12:48 PM
David---My congratulations on your first flight, and your beautiful plane!!
Tom
Ridgeland, SC
Old 06-04-2013, 12:56 PM
hydroguy2's Avatar
I see in one pic, it appears your gearleg is exposed....do you have all your fairings in place?
As long as you aren't overheating your engine, I wouldnt fuss with prop pitch. Get a little time on the motor then get all the legs and wheels covered up...including upper and lowers. She'll fly different
Old 06-04-2013, 09:01 PM
kevinsrv7.com's Avatar
kevinsrv7.com kevinsrv7.com is offline
Default Final conclusion
David, thanks for sharing your experience.
I'm interested to know if while troubleshooting the lack of fuel in cylinder #1, did you guys come across some FOD in that injector or do you think the obstruction just cleared itself.
Thanks.
www.kevinsrv7.com
Old 06-04-2013, 10:12 PM
Flyguytki's Avatar
Thanks.
We were unsuccessful in finding any FOD in the line or injector, however the injector is so small that i doubt you would be able to see it. Also the data shows that it cleared itself and the power came back, it fluctuated a bit when it did come back on line but there was power there.
I put another 2 hours on it tonight without a hitch, the machine is amazing.
