Old 08-03-2020, 06:38 PM
gfb gfb is offline
Default The dreaded baffle/Oil Cooler Crack
Just documenting here for those thinking they don't need to strengthen this area I'm on Condition Inspection #2, 592hrs and found this ugly crack through almost the entire baffle flange.
Talked to vans on the phone and we agreed that cutting the flange and adding a piece of 0.125x1x1 angle would be a good fix. So today I drilled out the rivets.
ID:	774  Click image for larger version
ID:	775  Click image for larger version
RV-9A - started 01/2015, completed 07/19/2018, 500hrs 03/14/2020
RV-10 - started 04/2020
Old 08-03-2020, 06:39 PM
gfb gfb is offline
Yes, I know those bolts are threaded too far. I'll be taking care of that with the repair as well.
Old 08-03-2020, 09:02 PM
OZCleco's Avatar
OZCleco OZCleco is offline
Same issue, pretty much the same repair.
Adding to the thread as a show of solidarity, knowing what a pain in the backside it was, start to finish.
ID:	798  Click image for larger version
ID:	799  Click image for larger version
Paid up 23/01/2020
Old 08-03-2020, 09:16 PM
When I made my baffles, I made a reinforcing angle out of mild steel from Home Depot. The angle underlapped the side reinforcing angle on the side baffle, and the attach screw on the cylinder. No cracks. Mild steel is much less susceptible to cracking. A few ounces heavier though.
SH
RV6/2001 built/sold 2005
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2021
Old 08-03-2020, 10:20 PM
drill_and_buck's Avatar
drill_and_buck drill_and_buck is offline
GB, Nice clean install. One option you might want to consider is to place a washer between the oil cooler flange and the aluminum spacer (as seen in Carl's pictures). There have been reports of cracking in the area where the spacer meets the flange. Placing a washer there will distribute the clamping force over a wider area.
Mike Draper
RV-8 N468RV
First Flight 11/13/2011
TMX0360, Pmags, CS
Bridgewater, MA
KPYM
Old 08-04-2020, 05:35 AM
fixnflyguy fixnflyguy is offline
Default Support device
When your all fixed up, as others have said, make sure you put some type of support to keep the cooler from flexing the baffle. I made mine from SS tubing attached to the case through bolts.
Name:	O320 top side.jpg
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 08-04-2020, 05:53 AM
Super Moderator
Behind jamnuts and throttle/mixture travel, the cracking baffling due to the oil cooler is the next most common finding. For those of you building, you should just add the stiffener from the start, as they all will crack around 200-300 hours.
I recommended for the plans to be changed reflecting this need.
Vic
Vic Syracuse
www.Baselegaviation.com
Old 08-04-2020, 06:05 AM
I saved that picture of Casper. A fine example of how baffles should look like. Thanks Bill.
Old 08-12-2020, 08:33 AM
beechrv9a's Avatar
beechrv9a beechrv9a is offline
Default The Dreaded baffle/Oil Cooler Crack
Oil Cooler Attach to Baffle Crack
History – Absolutely wonderful 2016 RV9A, 200+ hours, IO-360, Whirlwind 200RV CS Prop. Flew from snowbird hanger with all my tools and materials at X35 Dunnellon Fl. To 0W3 Harford County Md on July 1st. As is normal before a cross country flight, I removed the cowling for a good look see before the flight and oil change that was due. All was well and I had no issues on the flight which included a normal one stop gas and go at KFLO Florence, SC and subsequent dodging and diverting for TS along the route near Richmond VA., then up the Eastern Shore of Maryland for a 6.5 hour flight. After several other local flights and a round-trip Beach Day Flight to 26N Ocean City NJ, I decided to pull the cowling as I will be flying back to Florida soon. To my surprise, I discovered the infamous oil cooler baffle attach crack. The point is this happened after ~ 9 hours of flight since the previous inspection, so if you haven’t done so, reinforce the oil cooler baffle attach point. Many thanks to the staff at 0W3 Harford Air Services for tools, and materials to make repairs.
And the Fix in progress
Jim Buechler
RV 9A - N194HW
I/O 360, Whirlwind 200RV C/S, Slider
RV 10 - 313RT
Beechrv9a@hotmail.com
Old 08-12-2020, 10:55 AM
johnbright's Avatar
johnbright johnbright is offline
Default no can see smugmug photos
...The point is this happened after ~ 9 hours of flight, so if you haven’t done so, reinforce the oil cooler baffle attach point...
https://www.smugmug.com/app/photos?imageKey=sZvK2V8
https://www.smugmug.com/app/photos?imageKey=R5Pdz5N
https://www.smugmug.com/app/photos?imageKey=M7PxqG5
https://www.smugmug.com/app/photos?imageKey=6V9FnPf
Wish I could see rhe photos.
John Bright, RV-6A, N1921R reserved, at FWF
O-360, 8.5:1, vert sump, dual SDS EFI EM-5-F
links
