Keep VAF
Going
06-25-2020, 09:09 PM
Wanted: Pirep on GTX 23es
Looking to do a budget upgrade on my 9a avionics. Going with G3x Gdu 370 (non touch). Concerned I won?t have panel space in my center stack for everything thus looking at a remote transponder...specifically the gtx 23es which is of the vintage and does interface with the 370. I really can?t find much info and just wondering about functionality/buttonolgy through the 370 vs the easy of squawk code entry of a panel mount. Your thoughts and experience are greatly appreciated
06-25-2020, 11:21 PM
I have a never installed GTX 23ES with tray and connectors if you?re interested. Originally part of my Stein panel - since swapped to a GTX 45R.
C-185
J3C-65
S1S
RV-8 under construction
06-26-2020, 12:46 AM
works fine
I've been flying with the gtx23es on a non-touch G3x system since 2014, works fine. Enterring a new code does take a couple of button pushes more than a panel mounted unit. It's not ideal, but perfectly usable.
You'll also need a seperate ads-b receiver (I use a gdl39).
-Greg
Greg Blanck
RV-8 Completed March 2014
Redwood City, CA
RV-8 Build Log
06-26-2020, 06:45 AM
-Greg
Ditto including the GDL39, except for me it's been since 2015.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
06-26-2020, 07:03 AM
For those who are using the GTX23 for ADSB out, what are you using for your certified position?
Amir
RV-7
RV-10 - Sold
Supporting VAF since the first visit
06-26-2020, 07:06 AM
My GTN 650.
PP ASEL-IA
WAR EAGLE!
06-26-2020, 08:20 AM
I had one in my RV-10 with G3X legacy displays and liked it a lot. GTN650 as ADSB position OUT source and GDL-39 IN. Doing the same on my -9A except using GDL50R for ADSB IN.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2021
06-26-2020, 08:53 AM
I have a 23es with my touch system and it's great, no issues. Use a gtn650 as position source and gdl-39r for ads-b in.
In fact I'm thinking about selling the 39r to replace with a 52r (for the music), anyone interested in a good deal on a 39r?
RV-9A - started 01/2015, completed 07/19/2018, 500hrs 03/14/2020
RV-10 - started 04/2020
06-26-2020, 09:29 AM
A Garmin GPS-20A. My primary nav GPS is the built-in G3X non-WAAS.
Mike Hilger
RV-6 N207AM w/G3X, 1,800 hours +
South St. Paul, MN (KSGS)
A&P, EAA Tech Counselor
We're all here because we're not all there...
06-26-2020, 10:27 AM
I'm using GDL 39R and GPS 20A.
RV9A under construction--N781DM became an airplane 2/8/2021
Donated
Thread Tools |
Display Modes |
