Old 04-26-2020, 07:28 PM
BillL BillL is offline
Default Parameters for and Electronic Ignition controller.
I would like to see air-fuel ratio readout and some kind of data stream (or output discrete(s))
for A/F, MAP, CHT and OAT to drive an electronic ignition control module. These parameters could allow a controller to give best power timing, but automatically limit advance with high CHT and/or high OAT.
I would not mind doing the work to calibrate the system, but do not want more knobs to twiddle in flight, every flight.
Thanks.
Bill
RV-7
Lord Kelvin:
I often say that when you can measure what you are speaking about,
is of a meager and unsatisfactory kind.
Old 04-26-2020, 09:38 PM
gfb gfb is offline
Other than air/fuel (which requires an O2 sensor?), MAP, CHT, and OAT are already available on the CAN Bus I believe. You just need to tap in and listen.
RV-9A - started 01/2015, completed 07/19/2018, 500hrs 03/14/2020
RV-10 - started 04/2020
Old 04-27-2020, 10:27 AM
No, actually, an O2 sensor is not required- We know this because air mass flow can mapped using RPM, MAP, and InManTemp using calibration routine. It is the basis for an open loop speed density fuel system control method. I (as a development engineer) contracted with a controls group to do this on an engine fuel system controller and it was amazingly accurate. In our plane, we could then perform periodic checks at peak EGT to confirm the calibration. It is proven that this is a consistent way of determining A/F with minimal instrumentation.
The O2 sensor can certainly be used for precision, perturbation, drift and changes, but not required.
Fuel flow still has to come from the flow sensor.
Question: Are the Garmin CAN protocols open source or proprietary?
Bill
RV-7
Lord Kelvin:
Old 04-27-2020, 11:13 AM
gfb gfb is offline
Very coo! Don't most engine computers use an O2 sensor though?
It conforms to Bosch CAN 2.0-B and ISO 11898.
Old 04-27-2020, 11:25 AM
lr172 lr172 is offline
Most modern systems use RPM, MAT, MAP, and MAF (and CLT for warmup enrichment) for fuel flow and only use the O2 for fuel trimming, which is a fine tuning adjustment. Many only use narrow band O2 sensors, which are only accurate in the near vicinty of stochiometric. They indicate lean or rich of stoch, but no resolution on how much. In these cases, fuel flow outside of the economy range (i.e. acceleration) is purely off of the pre-configured tables.
Without MAF (i.e. speed density), one would have to have a lot of testing and data mapping to build appropriate tables for each engine configuration, but definately doable. It is what I did when I went to a custom EFI for my porsche, though I had wide band O2 to provide testing feedback. This was how early EFI worked.
Larry
Old 05-17-2020, 10:46 AM
bkthomps bkthomps is offline
I've got a simple upgrade that from a developer perspective should be real easy to code
for the SXM Music module, show the elapsed time or time remaining of a song....I had a recent flight where every station my passenger selected, was in the final 15-20seconds of the song, it seems like a simple addition to the code?
Another for the SXM Music Module, can we have a databar display of the song/artist playing?
Old 06-03-2020, 08:52 AM
Kentsrv7a's Avatar
Kentsrv7a Kentsrv7a is offline
Default Fuel Tank Totals
Would like to see the total fuel in each tank without having to go to the engine page. Maybe add them next to "Fuel QTY" like the other graph indicators, Oil PSI GPH, etc. or maybe above and below the graph line. Thanks!
Kent Stitt
[size="1"]RV-7A
TMX-IO-360w/ P-Mags, Hartzell CS Prop, Slider,
Dual Garmin G3X Touch w/ GTN-650
Old 06-03-2020, 10:09 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Default Dual Fuel Gauge
Good Morning,
If you open up the configuration menu on the GDU, and select Engine & Airframe, then select a Fuel Input, there is a selection for Display Options. Change this to Separate and you should be able to display your fuel gauge as described.
Justin
Garmin G3X Support
g3xpert@garmin.com
Old 06-03-2020, 11:00 AM
bjdecker's Avatar
bjdecker bjdecker is offline
Default Requesting Again...
On the G3X, Add a Arnav/EI Fuel or Shadin Fuel Flow output format in the RS-232 data stream selection. The would enable us to use Fuel Flow/Endurance calculator in the GTN 650, 750.
If I could use the GTN 650 Fuel flow/endurance planning capability, I could keep the 1/3 of the GDU screen available for things like Traffic, Approach Plate, Maps, etc.
Thanks!
B
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 06-03-2020, 12:34 PM
Planecrazy232's Avatar
Planecrazy232 Planecrazy232 is offline
Default Roll trim
For us manual trim autopilot guys, we get pitch trim commands on the screen. How about giving us roll trim indicators also??
Anthony
RV6-A "Aluminum Mistress"
Too many hobbies- not enough time.
2016, 2017, 2018, 2019, 2020, 2021 donor and happy to do it.
