Keep VAF
Going
04-09-2020, 04:11 AM
Loctite on AN fitting B nut
Is it good or bad practise to add blue loctite to the B nuts of AN fitting. considering the amount of vibration it seems like extra security to prevent the nut from loosening up.
Or is the standard tightning procedure sufficient to prevent this happening.
Thank you
Empennage, Wings, Fuse .. Done
Working on Finishing and FWF
Donation 2017. . . 2020
Chairman NVAV (EAA chapter 664 - Dutch experimental aircrafts builders)
Member EAA
Member AOPA
04-09-2020, 05:38 AM
Bad idea. Don't do it.
Noel
RV-6A N6NF
tip-up
flying
04-09-2020, 06:27 AM
I don't think there is any mention of loctite, or any other thread locking compound in AC 43.13. Flare fittings have been around for a long time now, and loosening of them is not a known issue.
Failure to tighten properly, however, is a human issue.
The old WWII MS-series, the current AN-series, and the 37-degree industrial fittings don't require loctite.
Most flare failures are due to improper flare formation during tube construction, or improper torque during assembly. The usual torque mistake is OVERtorque, which results in cracking of the flare on the tube.
IMHO, no need for loctite, but learn how to form the flare properly (Lots of important details here), and don't overtorque when installing.
My Two Cents, YMMV.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2021 Donation+, Gladly Sent
04-09-2020, 07:09 AM
+1
What PC said. Simple joint but takes practice.
Ben K.
A&P; RLSA - A,G,W/S Falco F-8L
50 yrs of flight and counting
Dues paid 2017 thru 2020
04-09-2020, 07:57 AM
They are assembled dry,,,no teflon tape either. Loctite hardens over time. You would not want a chunk of it break off and make its way to your engine.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2021
04-09-2020, 08:14 AM
OK, thanks all,
Yes, I am familiar with the AC.43.13 guidelines.
I will stick to that.
(Sometimes I tend to overthink or overdo things)
Member EAA
Member AOPA
04-09-2020, 08:34 AM
No harm in questioning "best practices", especially if it leads to an understanding of why it's considered best, recommended or required practice.
Finn
N214FL RV-4 Mazda 13B Renesis First flight 20 Feb 2021
N46AZ RV3-B Mazda 13B EFI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
04-09-2020, 09:43 AM
What has more vibration---your IO360 or a CAT bulldozer---careful with the answer. Think about it--
Enough said---
Tom
Ridgeland, SC
04-09-2020, 10:04 AM
Enough said---
Tom
Tell you what , your butt knows the difference.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
04-09-2020, 11:50 AM
Torque seal and forget
As your building, or re-building, a good practice is to apply torque seal which is a great visual inspection aid that will validate 2 things..one, that you have torqued it for final time, and second, it will visually let you know if it is loose, or has been loosened during inspection or maintenance. I torque seal mine at the B-nut and the ferrule /tube. I prefer bright orange, but lots of colors available. In fact, I do the same for every bolt on the plane.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Thread Tools |
Display Modes |
