Keep VAF
Going
01-15-2020, 04:36 AM
Spec of hoses for inverted oil
Can anyone help with part numbers for the fittings and hose used for inverted oil? I have looked at the components supplied by Summit Racing, of course I like the price!
Although they have been mentioned a number of times, the spec of the hose seems quite different to say Aeroquip AE701.
Has anyone used the components supplied by Earls Performance?
I'm referring to their Perfom-O-Flex and Swivel seal hose ends.
Although expensive, it's a little cheaper than Aeroquip and has a good spec.
I consider that the quality of these components is paramount to safety and of course meets the demands of the our overlords here in UK.
Any thoughts greatly appreciated, apologies for appearing paranoid over this!
01-15-2020, 05:51 AM
Fittings for Raven Install
See if this helps:
Randy King
Tampa (Wimauma), Florida
RV-4 N212CS (sold)
RV-8 N184RK (flying)
Flying an A320 to pay the bills
Exempt and gladly donating anyway - Current through March 2025
01-15-2020, 05:55 AM
I'm a big fan of racing hoses and fittings and have used Summit fittings and hoses on three Raven inverted installations. All are still working flawlessly. Just be sure to use the summit fittings on the summit hose and you can't go wrong. You'll save a lot of money this way and the hoses and fittings are much easier to work with than the aviation stuff.
If you have any difficulty crossing the AN fittings and hoses to the appropriate Summit versions, just give them a call. Their sales / support people are excellent.
Randy King
RV-4 N212CS (sold)
01-15-2020, 08:50 AM
Hose/Union Spec
Randy,
Many, many thanks.
This is my 1st inverted oil but my 4th RV!
01-15-2020, 09:22 AM
Typically -10 hoses for the supply and returns, -12 for the breather.
Earls does make high quality components. Their swivel seal hose ends DO make it easier for fitting orientation, but they do have their drawbacks.
WE typically use a convoluted teflon hose, with a truebore ID of .625, versus .500 for standard smoothbore teflon, and .565 for the -10 Performa Flex Hose.
Ours use crimped hose ends versus the resuables for the Earls products, and that does make it easier for the builder to make his own assemblies. Be sure to get a good selection of hose ends---different routings may require different hose ends.
Tom
Ridgeland, SC
01-16-2020, 03:46 AM
Swivel ends always start to eventually weep a tiny bit of oil.............
Ed
01-16-2020, 07:30 AM
Specs for oil lines
Thanks everyone, this forum is excellent.
The goal is now to ensure they meet the requirements in the UK; I will then tabulate the part no.s and their usage etc. along with some photos. I hope that will go some way to repaying your contributions and assist others encountering the issues around this aspect of their project.
Your inputs are greatly appreciated, thank you.
01-16-2020, 10:44 AM
Peter--we assume you are building an RV7?
Tom
Ridgeland, SC
01-16-2020, 10:49 AM
Ed---I wasnt going to rain on Peter's parade by saying that the swivel joints have a tendency to leak over time. Same as with the industrial versions in use on millions of applications. Easy to install and replace--pretty often. DONT use them on the suction side of a fuel system----the swivel joint can leak just enough to draw air thus creating a fuel flow loss---especially on long runs of hose.
Tom
Ridgeland, SC
01-16-2020, 04:32 PM
Tom
Hi Tom,
As a coincidence I just put a question on another thread, already answered.
http://www.vansairforce.com/communit...d.php?t=178717
It seems like you advice against using the swivel joints fittings. I was planning a couple of them to connect on the suction side of the fuel selector.
It would give me the opportunity to avoid 90 degrees turns in the suction line.
But I have to rethink that if this leads to leaks over time.
Empennage, Wings, Fuse .. Done
Working on Finishing and FWF
Donation 2017. . . 2020
Chairman NVAV (EAA chapter 664 - Dutch experimental aircrafts builders)
Member EAA
Member AOPA
Thread Tools |
Display Modes |
