Old 06-02-2021, 09:07 AM
PilotjohnS PilotjohnS is offline
Originally Posted by NYTOM View Post
Having had my FT-60 fail just last week I pulled it today and cleaned it out.
Didn’t find any debris and was able to lightly blow into the IN port to hear the turbine wheel spinning nicely. Wiring was checked and all grounds and voltages checked out. I reinstalled and pulled her out to test.
No Joy. Order is in and should have the new unit in a couple of days. Vic Syracuse told me when he inspected my plane that he liked the mount on the FW but suggested some insulation and shielding to keep it as cool as possible. My unit only had about 50 hours flight time but was actually about 15 years old. Probably electronic degradation. Same thing happened with my brand new 10 year old com. Sent it to ICOM and electronic degradation was the magic word for that too. Only advice I have now is to wait till you actually need it before you buy anything electronic.
it must have been all the lead in the avgas that coated the sensor window. That lead is a real problem, I heard Osh needs to rent a tractor to clean the field after AirVenture.
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2021, worth every penny
RV9A- Status:
90% done, 90% left to go
Firewall Forward 5% in work
Fiberglass 0%, thought i was building in metal?
www.pilotjohnsrv9.blogspot.com
Old 06-02-2021, 10:01 AM
MacCool's Avatar
MacCool MacCool is offline
Absolutely agree! If 93 octane, ethanol-free, lead-free, Lycoming approved "mogas" was readily available, I think that most of us would switch in a heartbeat.
RV-9A, 2011, bought flying
IO-320D1A
IFR certified
AFS 5400/3500, G5, 430W, some other stuff
Old 06-03-2021, 03:16 AM
NYTOM NYTOM is offline
Default Method to clean out lead.
Interesting. Iíve read posts by others that said dismantling the cube is almost impossible since something usually breaks in the process. I would love to test out your theory by cleaning out the lead. Does anyone know of a chemical liquid I could fill the cube with that would flush out the lead.
Itís worth a try.
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360 FP
Old 06-03-2021, 05:34 AM
MacCool's Avatar
Interesting. I’ve read posts by others that said dismantling the cube is almost impossible since something usually breaks in the process. I would love to test out your theory by cleaning out the lead. Does anyone know of a chemical liquid I could fill the cube with that would flush out the lead.
It’s worth a try.
Such products exist for firearms, but I have no idea how well they work even in that context, let alone whether or not they'd be suitable for use in an electronic flow sensor. I guess the value of trying such a thing depends on how bad you want to save the $200.
https://sharpshootr.com/no-lead/
IO-320D1A
IFR certified
Old 06-03-2021, 05:39 AM
PaulvS's Avatar
PaulvS PaulvS is offline
Hoppes no. 9 is the traditional gun barrel cleaner for lead, copper, powder fouling etc. but the side effects on a FT-60 would be uncertain.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, working on fuselage
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
Old 06-06-2021, 06:27 AM
MacCool's Avatar
Hoppes No. 9 works as well as anything for powder residue, and the smell is the most traditional thing about it , but it’s not great at all for dissolving lead IME.
IO-320D1A
IFR certified
Old 06-06-2021, 07:34 AM
Steve Steve is offline
My experience was that the lead turns into a grey goop after filling the spark plug electrode cavity with Hoppes #9 and letting it work overnight. You can clean the spark plug but I don't want it in my Red Cube.
Five Sierra Fox
RV-9A
Utah
Old 06-06-2021, 07:56 AM
Default Raise my hand
Sorry I should have raised my hand.
It was a joke, based on another thread that had gone off the rails.
John S
RV9A- Status:
Old 06-06-2021, 08:20 AM
MacCool's Avatar
IO-320D1A
IFR certified
