Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
  #21
Old 05-08-2021, 09:23 AM
Bavafa Bavafa is offline
Originally Posted by rocketman1988 View Post
I mounted my gsu25 on the subpanel and have had zero issues...
Same here and zero issues. In fact this is a preferred installation method by Garmin and VANs.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 05-08-2021, 09:38 AM
bjdecker's Avatar
bjdecker bjdecker is online now
Default Location...Location...Location
Not to be contrarian -- oh who am I kidding...
I put mine on the back of the GDU 460; Vibration survey passed at all engine RPM from 1000 to 2700, go figure.
Easy access too..
Sort of like telling bumble bees that they cannot possibly fly..
Click image for larger version
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 05-09-2021, 08:23 AM
JDA_BTR JDA_BTR is offline
Me too very happy on the back of the pilot 460
Ser 140142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 05-09-2021, 09:18 AM
rocketman1988 rocketman1988 is offline
Default I think
I think that garmin cautions against mounting it on the gdu due to the possibility of vibration if the gdu is not adequately supported in the panel. This doesn’t seem to be a problem in the RV aircraft as the instrument panel is pretty solid. I have talked to a bunch of folks who mounted on the gdu with no issues...
Bob
Aerospace Engineer '88
RV-10
N464RL
Dues+ Paid 2020,...Thanks DR+
Old 05-09-2021, 01:42 PM
KeithB's Avatar
KeithB KeithB is offline
But there are also those of us with mounts to the back of the G3X who do have vibration issues (periodic ADAHRS reversion and reboot) that Garmin blames on the location.
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, 24th in the air, >700 hrs
XP-400 Aero Sport Power, replaced with Lyc Thunderbolt 390
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 9/2020
Old 05-09-2021, 02:10 PM
PilotjohnS PilotjohnS is offline
Default GSU25
I would really really like to mount mine to the back of the GSU. It will leave me more room for the voltage regulator. Curious how many people have done this. Maybe it is time for a poll???
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2021, worth every penny
RV9A- Status:
90% done, 90% left to go
Firewall Forward 5% in work
Fiberglass 0%, thought i was building in metal?
www.pilotjohnsrv9.blogspot.com
Old 05-09-2021, 02:36 PM
Nova RV Nova RV is offline
I put mine there when I saw that Mitch Lock put it on the back of the GDU when he was building what would become the East Coast demo plane. As far as I know, that plane has never had an issue, nor I on mine.
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
RV-14A kit # 140243 (flying as of 11/18)
www.mykitlog.com/chrismoon/
Old 05-09-2021, 02:51 PM
Janekom's Avatar
Janekom Janekom is offline
My feeling is that if you are sure that the screws are tight, the only other option is that you have bad unit.
Jan Hanekom
South Africa
Approved Person nr 325
http://www.rvbits.com
RV10 - ZU-XOX - (Flying)
RV7A - ZU-JRV - (Flying)
RV10 - ZU-JVR - (Written off)
RV7 - ZU-LOL - (Flying)
RV10 - ZU-RVI - (Flying)
RV7A - ZU-MER (Bought back)
RV7A - ZU-JAD (Sold Flying)
Dues paid for 2021 WITH A SMILE
Old 05-17-2021, 05:20 AM
flysrv10 flysrv10 is offline
Originally Posted by flysrv10 View Post
I have good clearance between the cowl and fuselage. Don't feel excessive vibration, nothing more than any other RV I have flown. Garmin sez it is an "unusual" case.
If you want to be safe, I recommend that you fabricate the harness so you can locate it on the back of the unit if your choice location does not work. I cannot relocate mine due to harness length. Or wait for a couple of weeks until I install my replacement GSU and report back.
Got a new GSU25 and a roll servo. Apparently the roll servo was doing something weird on the network.
I still don't pass the vibration test but I no longer have G3X command a right steep climbing turn right at take off as it was happening with the old GSU25.
