Old 05-06-2018, 07:06 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Originally Posted by flysrv10 View Post
YOU ARE ON THE RIGHT TRACK. LOOKS GOOD. THE EXISTING RV10 TRAY IS 7 1/2" lONG by 5" deep. I GOT THIS INFO FROM VANS BATTERY THAT HE SELLS. IF YOU NEED A MORE PRECISE DIMENSION, I WILL NEED TO OPEN THE TAIL CONE AND MEASURE. YOUR CALL; NOT TOO MUCH WORK FOR THE BEST FIT. I SEND YOU N INSTALLATION PIC THAT I FOUND ON THE WEBSITE. I MAY HAVE TO SEND YOU THE PIC DIRECTLY TO YOU EMAIL UNLESS I FIGURE OUT HOW TO DO IT HERE.
Just measured mine.
7.50 x 5.063 with a rounded inside bend radius on the long sides only.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-06-2018, 07:21 PM
Steve Melton's Avatar
Steve Melton Steve Melton is online now
what do you guesstimate the size of the radius on the long side?
Originally Posted by az_gila View Post
Just measured mine.
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 05-07-2018, 09:50 AM
flysrv10 flysrv10 is offline
STEVE,
I MEASURED MINE AND I AM GETTING 5"X7" TAKING INTO ACCOUNT THE RADIOS. DON'T KNOW IF THE FLANGES ARE BENT GIVING THE FRACTION MEASURED BY AZ_GILA (THANKS FOR TAKING YOUR DIMS AZ_GILA). I WILL SEND YOU A PIC TO YOUR PERSONAL EMAIL AFTER TGHIS EMAIL. THANKS.
Old 05-07-2018, 10:01 AM
don't worry about the radius at the bottom. we will take care of that with a chamfer for clearance. we want the measurements of the top edges. seems like we lost 0.5 inch going from 7.5 to 7.0.
STEVE,
Steve Melton
Cincinnati, OH
Old 05-07-2018, 02:05 PM
az_gila's Avatar
Smile
STEVE,
Let me verify the 7.5"
I might have just assumed the previously stated dimension was correct and that I had it on the major markings on the ruler.
Gil Alexander
Old 05-07-2018, 03:39 PM
Gil, I'm trusting your first measurement. Print underway.
Steve Melton
Cincinnati, OH
Old 05-07-2018, 04:49 PM
az_gila's Avatar
Smile
Going out in the heat to check the dimensions, but this pic shows the radius at the bottom of the tray -
Gil Alexander
Old 05-07-2018, 06:22 PM
az_gila's Avatar
Thumbs up
Steve, I just checked, it is 7.5 inches on the long dimension.
A 3/8 drill bit fits nicely inside the radius shown on the bottom of the long sides of the tray.
Gil Alexander
Old 05-07-2018, 07:21 PM
thank you. we are good to go. the print is almost done. I've been out flying doing a check flight after my condition inspection. the only mod I made was to drill off the seat back hinge upper adjustment to allow the seat to go fully back. small change but I like it.
it's a nice part. on the make.
that's a nice little tray.
smooth backside and perfectly flat
Steve Melton
Cincinnati, OH
Old 05-10-2018, 07:15 PM
Thumbs up
Got all the goodies Steve pass thanks to Amanda nice job! Will install tomorrow. Let's see how they survive the beating. Will report here after first thousand hours on them
