Old 03-14-2021, 07:46 AM
jaradtke's Avatar
jaradtke jaradtke is offline
Default infill
Steve,
how about an insert to close up the space created by the angled control panel on the HDX
https://vansairforce.net/community/a...6&d=1613539308
Jeff Radtke
Lutz, FL
RV-7A - SOLD
RV-7A - New Build
Tail Feathers - Complete
ER Wings - Complete
Fuselage - Complete
Finish - Started
Old 03-14-2021, 11:23 AM
Steve Melton's Avatar
Originally Posted by Walt View Post
Could you make a contoured mount to fit a GA35 antenna to the curvature of the RV8 skin just aft of the seat bulkhead?
step 1. make a RV8 skin.
actually that is step 2.. step 1 was to run 4 miles.
step 2. make a GA35 pattern and place on RV8 skin.
step 3. extrude GA35 pattern to skin.
placement of the GA35 antenna leading edge on the skin is 6 inch aft of bulkhead and the GA35 antenna centerline is 3 inches from fuse centerline on the pilots side. I didn't know the best placement so I just put it there for now to do a fit check. the first print didn't include edge radius and it was a quick print. I usually insist all bolted flanges are parallel for structural integrity but in this case the wedge angle is low and the clamp is low and there are four bolts so it will be fine.... it's not structural.
we could also make a complementary interior piece to allow the nuts to be parallel to the bolt heads. that would be a good thing.
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 03-16-2021, 04:45 AM
Default RV8 GA35 antenna aft fuse mount
with interior piece for bolting parallel surfaces. I don't believe an alum doubler is needed for this small antenna. drill the skin, bolt it up and you're done. when you drill the skin, firstly mark the hole center with the plastic boss and then drill perpendicular to the skin. otherwise the hole center will slide.
Steve Melton
Cincinnati, OH
Old 03-16-2021, 06:16 AM
Originally Posted by jaradtke View Post
Steve,
send me a sketch of your concept and I'll take a look at it. thx, Steve
Steve Melton
Cincinnati, OH
Old 03-17-2021, 07:17 AM
Default Aileron Gust Lock
several of these are being shipped as of late so beware that they can and will kill you if you do not remove them before flight.
1. the aileron gust lock is only required on one side to secure both ailerons. put it on the pilot side and attach a streamer to it so you will see it.
2. have a place to store the gusts locks in the aircraft to be sure you have everything accounted for a flight worthy aircraft.
3. get in a habit of moving the controls to full motion when you do a preflight inspection.
4. follow your preflight checklist every time and do a control freedom check.
5. be fully alert when you fly... not sick, tired, or anxious.
that is all.
Steve Melton
Cincinnati, OH
Old 03-20-2021, 06:58 AM
Default Bicycle
When your wife hasn't ridden her bike in 10 years but has a strong emotional attachment and says she made ride it any day now so it needs to have quick access....and you are trying to declutter, what to do? a very smooth ball bearing pully. it's important to keep the Ladies happy.
Steve Melton
Cincinnati, OH
Old 03-20-2021, 07:52 AM
Walt's Avatar
Walt Walt is offline
Steve, I love it! Shoot me an email so we can arrange getting a few.
Walt
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 1900+ hrs, New Titan IO-370, Bendix Mags
Old 03-20-2021, 07:55 AM
Walt, tell me your preferred location and I will adjust the model to that exact location. give me some dimensions to lock in the perfect position for these. I'll send you a couple these evaluation. no cost. Steve
I saw a photo on the web of this one and understood the problem. gap on one side. difficult to bolt up. probable paint damage over time.
Steve Melton
Cincinnati, OH
Old 03-20-2021, 09:21 AM
It would be really nice to have threaded inserts built into the inner piece.
Dave
Old 03-20-2021, 09:23 AM
Dave
too thin, can't do it. it needs to be as thin as possible.
Steve Melton
Cincinnati, OH
