Old 07-20-2021, 05:59 PM
gassman gassman is offline
Default Potato potata
Mr indecisive here,
Rv-7 build. Trying to decide between aerosport io-375 with ww300 or io360 with hartzell ba prop. Thoughts?
Old 07-20-2021, 06:35 PM
wirejock's Avatar
wirejock wirejock is offline
Default Choices
Originally Posted by gassman View Post
Mr indecisive here,
What about an IO360M1B with WW300?
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 07-20-2021, 06:52 PM
Flyingbeard Flyingbeard is offline
Thumbs up One data point
I have a Aerosport Power IO-375 and WW HRT 74. No issues and has been easy to start even when hot. 117 hours and very happy with my Engine.
Mark Beard
RV-8, N23MB
W48
Old 07-20-2021, 11:56 PM
tgmillso tgmillso is offline
If you ever want to run Mogas or unleaded ULP, the youíre likely limited to 8.5:1 compression ratio. Handy if you end up somewhere that doesnít have 100LL available, or you just donít want to fill your engine with corrosive lead bromide salts. If you build a light aircraft, even 180hp in these things feels like a boatload of power and youíll never have to worry about not having enough HP to get out of somewhere short you got into.
Tom
RV-7, IO-360 M1B, Hartzell BA
Old 07-21-2021, 04:17 PM
SeanB's Avatar
SeanB SeanB is offline
I own an IO-375 and I'm sure I'll love it once I fly. Darren and the crew have been awesome with support at Aerosport. In the course of shopping for props, I ran across information from WW stating they were no longer endorsing their prop on this engine. I don't recall if it was a specific model or all of their props. Could have also mattered if counterweighted crank and high or low compression. I eventually got information from Hartzell for their BA prop. Okay to use, with a fairly normal "continuous operating range limitation" (again matters of counterweighted or not/compression) to avoid. I decided to go with the Hartzell. I'm at 7.8/1 and non counterweight. Plus, -7s usually benefit from weight up front.
SEAN BLAIR V7
Colorado Springs, CO
https://eaabuilderslog.org/?blprojec...&listcat=&sid=
2020 VAF SUPPORTER
Old 07-21-2021, 04:41 PM
SeanB's Avatar
More discussion:
https://vansairforce.net/community/s...prop+Aerosport
SEAN BLAIR V7
2020 VAF SUPPORTER
