Old 06-06-2021, 12:46 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Default FlightCom 403 Clarity...
I have FlightCom 403M Panel Mounted Intercom with Garmin SL40 in my RV-12. I’m told the Tx sounds very good when I transmit with very little background noise.
Rx sounds really good if I use “Isolate” function. When I use “All” the Rx has some background noise when I transmit. Listening is also not as clear in “All” Vs. “Iso”.
I have LightSpeed Zulu3 for pilot and Dave Clark for Co-pilot. I have tried several other headsets including Zulu2 on the right side with same result.
The problem is not the end of the world, but I’d like to fix it if possible. Any thoughts?
Jim Stricker - EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 690
