I already have a panel put together for my not-yet-flying RV kit that has separate landing light, taxi light, and wig-wag switches based on the Bob Nuckolls Wig-Wag circuit design. Instead of using an SSF-1 Wig Wag relay I have decided to purchase the Duckworks solid state Wig Wag controller. This controller uses a SPDT switch where down is off, middle is on, and up is Wig Wag. Has anyone used this controller for their existing three switch design? if so how did you wire it?
My initial idea is to stick the switches AFTER the wig wag controller so when the Wig Wag switch is in the 'On' position then each switch turns on and off the landing/taxi lights as normal. Is this weird? it would mean having the Wig Wag switch centered all the time... looking to hear others thoughts on this, thanks.
Matt
Matt
