What I wanted to know, is if the 9, structurally can handle rolls, loops and wing overs, that's all
Sure it can. You can safely loop or roll just about any airplane. You just have less strength margin and less margin for screwups compared to airplanes designed for aerobatic stress. Capable and suitable are two different things though.
...if someone wants to do aerobatics in a 9/9A they had better already be an expert in them to be able to keep them gentle and stay well within the structural limits.
For US aerobatic category an aircraft must be stressed for +6/-4 Gs.
The RV-9, -10, and -12 are not designed to these limits.
Is the only difference between the 9 and 7 the wings? I haven't noticed any other changes while building my 9a, but I don't have the manual for the 7. The fuselage appears to be the same, empennage the same, larger engine allowed on the 7, but what else?
Could a person build 9 wings and 7 wings and have two planes?
OK, that makes sense. I thought the plans said for 7 and 9, but looks like I was wrong. I suppose you could build 2 tail-rudders and wings, but quite a bit of work and effort. It would be easier to just decide - aeros or not.No, the horizontal tail is quite different!
I struggled with this for a while. I was leaning toward the 9 since I want to do a lot of x/c flying, but really liked the idea of having the higher margin of strength not only for possible aerobatics, but just a little extra comfort in turbulence, etc. I know, no way turbulence is going to hit 4-5G, but still...
