Old 01-15-2022, 07:22 AM
bobnoffs bobnoffs is offline
Default bearings
hi all, does anyone know of a supplier of just needle rollers? i would buy either a stock dimension or order a custom size. thanks for any help.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
RV-12 airworthiness cert. 11/30/2021
Old 01-15-2022, 08:26 AM
dpansier's Avatar
dpansier dpansier is online now
I have used Dowel Pins in custom size, low speed applications, McMaster has a wide selection.
Don Pansier
Green Bay, WI (GRB)
RV-7
Antennas for Experimental Aircraft
www.deltapopaviation.com
Old 01-16-2022, 01:01 AM
DanNiendorff DanNiendorff is offline
https://www.mcmaster.com/needle-bearings/
RV-14A 140658 in progress
Zenith CH801 & 2500A amphibs - flying
Dues 2022 ✅
Old 01-16-2022, 10:20 AM
harleyl harleyl is offline
Default Loose needle rollers
If you want the needle bearings without a cage you can search for “loose needle rollers”.
Pat Langston
RV-8 slo build
Elberta, AL
Old 01-16-2022, 01:13 PM
yes, i think they are available somewhere, i am going to have to talk to someone at timken etc.
this is for an evinrude outboard. i am following another lead that the needles are still available for a lawnboy lawn mower!
Bob Noffs
n. wi.
Old 01-16-2022, 03:11 PM
BillL BillL is offline
They used to be made by Torrington, Bob. My information is 30 yrs old.
Edit: OK, maybe 50 yrs old.
What diameter/length do you need??
Lily Bearing might have a listing.
Bill
RV-7
Old 01-17-2022, 06:37 AM
bill. thanks i will check it out. .078'' and .612''.
Bob Noffs
n. wi.
