Michelin air stopper tubes
RicoB
Patron
Does anyone know if Michelin has the air stoppers tube for the nose wheel? Spruce has for mains but I don’t see the smaller size.
Yea, get rid of the tube with either the Beringer on Grove tubeless wheels.
Unfortunately, all the 11:00x5 tubes are "not so good" (that's being polite). I used to change mine every year or two just to be safe, finally installed the Beringer and never looked back. If you ever have a flat away from home, you may regret not changing it to something better when you had the chance.
Recommend you keep it aired up to 40-50psi.
