  #81
Old 01-21-2021, 10:06 PM
whity1231$ whity1231$ is offline
Default Adel clamps
I did what others suggested, safety wired them together. If you have to, use a longer bolt.
Old 01-22-2021, 06:24 AM
Bob Y Bob Y is online now
And use AN3 bolts instead of #10 screws where possible. Easier to tighten.
Bob Y - builder 12iS E-LSA
N569TT first flight 2/9/2020
Old 01-22-2021, 06:18 PM
JwWright57 JwWright57 is offline
Originally Posted by Bob Y View Post
They’re castellated nuts with Cotter Pins, no not an issue.
Castellated nuts? I don’t see that
Click image for larger version
Jeff Wright, Charlotte NC
Rv-12 started!
Tail 99% done
Wings 99% done
12IS fuse kit 99% done
Finish kit 95% done
Avionics kit 1% done
Dues paid 2020
Old 01-22-2021, 08:30 PM
See post #39. They’re Castellated on the iS mount.
Old 01-23-2021, 07:15 PM
Sorry Bob, but i just don’t see that. What plans page has that? This pic is the latest version i could find.
Rv-12 started!
Tail 99% done
Wings 99% done
Finish kit 95% done
Dues paid 2020
Old 01-23-2021, 08:27 PM
See page 5 of the KAI that came with my Powerplant kit.
https://www.dropbox.com/s/q75bmihfb3...stall.pdf?dl=0
Old 01-24-2021, 08:19 AM
DaleB's Avatar
DaleB DaleB is online now
Mine (S/N 120222) uses castellated nuts and cotter pins. In one of the Skyview installation sections I found a picture of one of the factory planes that showed the same part attached the same way. I don't know when they made the change, but originally they used cotter pins.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 01-24-2021, 11:08 AM
Thanks Bob. The engine kit I received around Christmas has locknuts and a revison for that page (8/19) .
Which is good lol since thats the hardware they sent me.
Rv-12 started!
Tail 99% done
Wings 99% done
Finish kit 95% done
Dues paid 2020
Old 01-24-2021, 02:03 PM
Received mine May of ‘19. Maybe Scott can share what prompted the change?
Old 01-25-2021, 12:07 AM
rcarsey's Avatar
rcarsey rcarsey is offline
I second that! Mine uses cotter pins. The only issue I had was that after torqueing, I couldn't install the cotter pin for 2 reasons.. the castellation didn't line up with the drilled hole (when does it ever!?), and also there was interference between the standoff and the cotter pin during insertion.
I had to make sure the bolt's drilled hole was up/down and not left/right. So maybe with locknuts, there's a better probability that builders will get the torque closer to spec.. ?
Rob Carsey, North Brunswick NJ
RV-12iS (N713) / Completed 12/2020
ASEL, Glider, AGI/IGI, LSRM-I, FCC GROL
