Fuel flow transducer (red cube) problem
bob888
My previously reliable FT-60 red cube fuel flow transducer has apparently failed with readings bouncing all over but generally on the very high side. I can't see a problem with the wiring and wonder if there is a way to troubleshoot the transducer or possibly a problem on the G3X system side, specifically the GEA24 engine monitor module. Any thoughts or suggestions appreciated.
