w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 05-25-2023, 07:38 PM
nohoflyer nohoflyer is offline
Default Electric flap weldement “play”
I’m installing the weldement which moves the flaps. I’ve secured them on the sides into the plastic, notched pivot blocks. The blocks screws have been tightened to the bulkhead.
My question is how easy should this thing move up and down? Because now it takes a few pounds of pressure to rotate it. What would be the solution? Widening the holes in the pivot blocks? Or is this normal?
RV-7A builder
A320 Capt at some airline
T-37/T-38/KC-135
C-177/172
Piper Warrior
2023 donator
Emp complete
Wings complete
Fuselage 99% complete
Beginning finishing kit
Working on fiberglass tips
25% put down on engine
Old 05-25-2023, 08:14 PM
wirejock's Avatar
wirejock wirejock is offline
Default Bolts
I found it very tight as well. Curious what others have done.
The rudder weldment was also really snug so I used a drilled bolts and castleated nuts to get the tension perfect then pinned with cotter pins. I can always adjust them tighter.
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/01/2023, plus a little extra.
RV-7A #73391, N511RV Registered
Disclaimer
Old 05-25-2023, 11:47 PM
agent4573 agent4573 is offline
Misread this at first... Have you put the center block in yet or just the ends?
www.rv7build.com - out of date, will be updated soon
N69ER - built and flying - 2022 Bronze Lindy
Old 05-25-2023, 11:56 PM
Tommy123 Tommy123 is offline
Get it completely assembled before modifying anything.
Old 05-26-2023, 07:11 AM
Right now just the ends. Although it seems that right now the weldement is under less friction than if another block is added to the equation
RV-7A builder
T-37/T-38/KC-135
C-177/172
Piper Warrior
2023 donator
Emp complete
Wings complete
Old 05-26-2023, 07:21 AM
lr172 lr172 is offline
same here. A bit of work with sandpaper on your finger will relax the bore a bit for freer movement.
Old 05-26-2023, 09:12 AM
bjdecker's Avatar
bjdecker bjdecker is offline
Default Different approach...
Instead of trying to "open the bore" of the UHMW blocks, I used a piece of fine emery cloth and "red" 3M scotchbrite pads to polish the ends and middle section of the flap torque tube (aka weldment).
From there I beveled the ends of the tube with a 45° chamfer, debured, and worked over with some 400grit wet/dry to smooth the tube ends.
I applied a light coat of Lithium wheel grease (white, water proof) to the polished sections of the tube. Place two AN960-10 washers in between the center bearing block halves (F-680) -- this makes up for the material removed when you slice the block in half. Torque all AN3 bolts to spec (~25inLbs).
The torque tube should hold its position without drifting down, but be easy enough to move by hand without any "grunt."
--- As an aside, I upgraded the flap push rods (F-759A) to the hex version from the RV-9 (VA-256) --- I know, I know, it won't work...
Brian Decker
EAA Technical Counselor
RV-7 (Flying)
Old 05-26-2023, 09:48 AM
HFS HFS is offline
Default Longeron Alignment ?
You might also consider checking the side-to-side alignment of the supporting longerons. If the flanges to which the UHMW blocks are attached are not in good "alignment", the blocks will "tip" just enough to make the drag you are talking a about when they are tightened down. Also, you might check the fore and aft alignment of the blocks in their mounting holes in the longerons - if the blocks are not parallel when bolted down, you will create drag as well.
My Rocket, required such "shimming".
YMMV - But it is worth considering.
HFS
Old 05-26-2023, 09:52 AM
PilotjohnS PilotjohnS is offline
Default Just me
I did not need to do anything to my blocks, but I did have to remove some of the powder coat (paint) from the rod to get it free.
I would make sure the blocks are running on the steel flap shaft without any powder coat interference.
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2023, worth every penny
RV9A- Status:
Flying June 2023
www.pilotjohnsrv9.blogspot.com
or builders log here on VAF: Pilotjohns
Old 05-26-2023, 10:16 AM
HFS
The blocks are bolted to a bulkhead not the longerons.
RV-7A builder
T-37/T-38/KC-135
C-177/172
Piper Warrior
2023 donator
Emp complete
Wings complete
