w/a Donation
VAF on Twitter:
@VansAirForceNet
Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
Old 03-27-2023, 11:04 AM
Steve Barnes Steve Barnes is offline
Default Feed back on Uavionix wing wing tip ADS-B in and out
Going to install ADSB-B in and out and strongly considering Skybeacon for a flying RV. Looking for pros and cons.
Thank you
Steve Barnes
Old 03-27-2023, 12:08 PM
moespeeds moespeeds is offline
I've got in/out in my wingtips. It works well, no issues.
Moe Colontonio
Cherry Hill, NJ
RV-8 N495T
Old 03-27-2023, 12:14 PM
azrv6's Avatar
azrv6 azrv6 is offline
Skybeacon only provides ADSB out. Simple install. Dependent on how decent your existing transponder is so make sure it is working correctly. Will need to tweak the threshold value (lots of threads on here about that). Can be installed in the wingtip if that is a configuration that might make sense for your specifics.
Dave Binkley
1996 RV-6, O-360-A1A, C/S (builder)
1932 Monocoupe 110, Warner 145 (https://www.monocoupe.blogspot.com)
Sedona, AZ
Old 03-27-2023, 12:24 PM
MarkCFI MarkCFI is offline
I have both the SkyBeacon and the Skysensor. Gave me strobes and ADSB in and out.
RV-6
N456PC
Donated 2023
Old 03-27-2023, 04:38 PM
terry.mortimore terry.mortimore is offline
Default Wing tip mounting
I mounted mine inside the right wing tip, working as it should. I did not want to give up my tail strobe light.
Click image for larger version
Terry Mortimore
RV-6A flying
Based CYAM
