w/a Donation
VAF on Twitter:
@VansAirForceNet
Go Back   VAF Forums > Model Specific > Rocket
  #11
Old 09-23-2023, 09:26 AM
JonJay's Avatar
JonJay JonJay is offline
Talk with Wayne at Phlogiston. He may be able to help.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 09-24-2023, 02:53 PM
vfrazier's Avatar
vfrazier vfrazier is offline
Wayne has retired and closed his shop. Sold the equipment too, unless I'm mistaken. Probably at least 18 months ago.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
https://www.cleavelandtool.com/
RV and Rocket Tools, Accessories, Tailwheels, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 09-24-2023, 03:05 PM
vfrazier's Avatar
Originally Posted by Capflyer View Post
I am building a HRII and just started the center section. Trying to figure out the best way to match drill the already drilled spars and W-420 spar splice plates to the center section F-404's. Open to hearing all suggestions.
The other suggestions from Scott and David are certainly options. Another one is to NOT drill any of those close tolerance holes, but simply extend the outboard portions of your existing RV-4 parts, i.e. the #3 and #4 bulkheads.
Here's a PDF with photos of how to do this. It's probably the easiest of the options presented here.
Be sure to maintain the fore and aft relationship to the spar, probably by inserting the spar, before drilling the "U" shaped side plates. Same for the bottom plate. Afterall, the spars must fit inside when you're done... and the bolts must go in the holes!
Even if it's not your final choice on how to do this, I think you'll find the info useful.
(Note: #3 is the forward face of the 404 bulkhead.)
(Note also... the HR2 uprights are parallel to each other, while the F1 parts are staggered a bit. IOW, the rear uprights are as bit closer together, L&R. That change was made to help the one piece F1 side skins lay down better.)
Vince Frazier
www.f1aircraft.com
Old 09-24-2023, 03:46 PM
JonJay's Avatar
Thx Vince. Haven’t spoke to him in a while.
Bucker Jungmann
RV1 - Proud Pilot.
Old 09-25-2023, 06:19 AM
Capflyer's Avatar
Capflyer Capflyer is offline
Thank you Vince. I actually found this on the DB link you sent me last year which I had forgotten about until reminded. Extending the RV4 pieces seems like the easiest and most accurate way to proceed. They were already assembled but it should be easy enough to drill out a few rivets.
Mike
HRII - Building
RV8 Hot Rod "Drone Killer" - Built & Flying
RV8 Blue Nose "Look'n Good" - Sold
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 09-25-2023, 06:57 AM
Freemasm Freemasm is offline
Of course, my match marking/template approach for mod'ing the 404 is better.
I truly have no idea if anyone else build theirs that way.
