w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 05-08-2023, 08:42 PM
SonexGuy SonexGuy is offline
Default Location for fuel return bulkhead fitting?
I will likely have a fuel injected engine, and those need a fuel return to both tanks. I've not seen an RV-7 wing installed, so I don't know if certain locations or configurations would interfere later on. I'm hoping someone in the RV community can help.
http://www.mykitlog.com/users/displa...g=305899&row=1
Anyone have photos of their successful installation? Left wing has a flop tube, and that's the one in the photos.
Mike Smith
Maynard, MA
(Scratch built a Sonex. Building an RV-7.)
http://www.mykitlog.com/mikesmith
https://www.youtube.com/user/mikesmith208/videos
Old 05-08-2023, 10:19 PM
pilotkms's Avatar
pilotkms pilotkms is online now
U need to do some research on Fuel Injection systems. NOT ALL require a return fuel line. Look at Precision Airmotive RSA-5 and Airflow Performance. I believe each has systems that DO NOT require a return line. I have the RSA-5 and NO return line. Others may or may not.
Keith
RV 7A RV #9700 May 2017
N325KS the Flying “K”
Built in SoCal KCCB, now in GA @ KPXE
1,200+ Hours & 7X cross the USA
OSH flyin 2018, 2019, 2022 & 2023
Petit Jean 2019, 2021, 2022 & 2023
Old 05-09-2023, 08:02 AM
Mike----IF you are using the SDS or EFii systems, yes you'll need returns to the tanks. We like them to be near the top of the rib, about 1 inch down, but inline with the supply fitting. LOL---just makes hose duplication easier.
Lots of ways to do it.
Standard mechanical injections do NOT require full returns to the tanks.
Tom
Tom Swearengen, TS Flightlines LLC, Aircraft Specialty Flightlines
Ridgeland, SC
www.asflightlines.com
Old 05-09-2023, 06:24 PM
I'm currently looking at a UL engine (520iSA) with FI. That requires the return lines.
So going with the need for the returns, I want to make sure I don't put them somewhere where I'll find out later that there is interference with something when I go to install the wings.
Mike Smith
Maynard, MA
Old 05-09-2023, 07:54 PM
riseric's Avatar
riseric riseric is offline
I put my return to tanks fuel line just above the fuel line feeding the engine.
That way, in the cabin both are parallel to each other from the firewall to the fuel selector.
This is on a -8 so they are bottom left on the firewall.
I presume it's not the same for a -7.
Eric,
2023 =VAF= paid
RV-8 SB #83274
Grove Airfoiled Gear, Wheels & Brakes
VPX-Pro, EFII System 32, EarthX batteries
Aerosport IO-375, MTV-9-B/183
Skyview HDX
C-GEMQ, RV-8, "Dragonfly", flying
C-GNFJ, C72R Cutlass, flying
Old 05-09-2023, 09:06 PM
Mark33's Avatar
Mark33 Mark33 is offline
All of your fuel line plumbing should be able to mirror that of the SDS and EFII systems. There’s no need to reinvent the here. You can’t go wrong with Tom’s advice.
Mark H.
RV-7- IO-360, EFII, Whirl Wind C/S, (Built and sold)
RV-4- O-320, Catto three blade, P-Mags (Sold)
RV-8- IO-360, Hartzell C/S (Flying)
RV-7- Sold project
RV-14- Building
Old 05-10-2023, 07:42 AM
riseric's Avatar
Default Oh, the wing...
Mike,
I didn't get that it was the wing you were talking about.
Here's how I did mine, I'm not saying it's the best or perfect way to do it, but it works for me.
If I would change one thing, it would be a shorter return line in the tank.
I was concerned about warmer fuel returning too close to the pick-up.
I went for the middle bay, the second would be far enough I believe.
No flop tube in mine, just keep the return line clear of it.
Then, a custom tube between the fuselage and wing.
Here's a few pics.
ID:	42204  Click image for larger version
ID:	42205  Click image for larger version
ID:	42206  Click image for larger version
ID:	42207  Click image for larger version
Eric,
2023 =VAF= paid
RV-8 SB #83274
Skyview HDX
Old 05-10-2023, 09:13 AM
Ralph Inkster Ralph Inkster is offline
Mike- the general location Eric used for his return bulkhead fitting is fine. You could locate the bulkhead fitting higher or lower if you prefer. The 3/8 tube extension Eric employed is not required & in your case would be an obstacle to your flop tube operation.
Ralph
Now retired - my builder assist shop now closed,
