w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 04-10-2023, 06:31 AM
mikelupo mikelupo is offline
Default RV-10 Air filter box problem
Sorry. I have no photos to support this post.
This is a flying RV-10 (1100 hours) that uses the Van's provided filter airbox for the K/N-E3450 air filter.
I noticed during condition inspection that the filter does not fit snug at the top of the airbox anymore. I can see about a 1/4" gap. Thinking the air filter shrunk from washing/drying and re-oiling, I purchased a brand new one. Same outcome. My only conclusion here is that the airbox itself is the issue.
I think the problem is that the lower part of the air filter box has lost its "stiffness" or shape and no longer provides enough support to keep the air filter snug at the top.
Aside from ordering a new airbox kit (which are back-ordered), I'm curious what other owners have done to address this. Surely I can't be the first.
Mike
RV-10 (purchased)
Sonex builder - EAA chapter project
PA-28-181
PA-28-140
Old 04-10-2023, 06:41 AM
Tooch Tooch is offline
Epoxy a sheet of aluminum on the bottom of the airbox. It will also keep the filter from rubbing through the fiberglass.
Old 04-10-2023, 07:14 AM
lr172 lr172 is offline
+1
I add a piece of Alum to the bottom to prevent the F/G from wearing away. In your case, just modify size or qty of Alum sheets to get the height you need. However, be sure to match drill the drain holes.
Old 04-10-2023, 07:18 AM
larrynew's Avatar
larrynew larrynew is offline
+2
500 hours and filter still fits perfectly.
Larry New
RV-7A - Built, flew 1000 hrs, 48 States in 7 Days, sold
RV-10 - Built, flying 700+ hrs, Alaska with 4 RV-10s
RV-PP - Built, Pedal Plane, grandkids flying
RV-12iS - Building, fuselage
VAF on Annual Autopay
Old 04-10-2023, 08:31 AM
rvanstory's Avatar
rvanstory rvanstory is offline
Originally Posted by larrynew View Post
+2
+3 Same with my RV-10 after 420 hours.
Randy Vanstory
Flying RV10 - N783V
2021 Sun N Fun Reserve Grand Champion
2021 Oshkosh Bronze Lindy
1st Flight 08/20/2020 / Current Hrs - 475
Donation Happily Made 2023
Old 05-05-2023, 10:25 PM
dhmoose dhmoose is offline
Default K/N E3450 size discrepancies
For what it is worth, I have seen the filters dimensionally change after a year of use. They typically shrink circumferentially and it is noticed by finding the old filter having space between it and the small tabs that keep it in place. I vaguely recall Vans speaking to this issue years ago but it seems like the only remedy was to replace the filters annually as opposed to cleaning/oiling the lifetime filters when needed. During my inspection today, I removed the air box and saw that the old filter didn’t seem altered. When I went ahead and placed the new one in to compare, the new one was dimensionally smaller in height and didn’t make contact with the top plate allowing air to bypass the filter. When I compared the two filters side-by-side on the bench, there was an an obvious height difference. Strange.
David Halmos
RV-8, RV-10
Portland, OR
Old 05-06-2023, 08:14 AM
Walt's Avatar
Walt Walt is offline
Do a search on "shrinking air filters".
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, AFP FI, MTV-9 prop
Old 05-06-2023, 08:37 AM
+2
Interesting. 85 hours on the one in the Rv-10 and the bottom shrank in diameter so much the filter no longer sealed against the air box. I assume the bottom sees more fuel exposure in shutdown than the top and that was the causal factor.
The filter was cone shaped when I removed it.
The ones on the RV-6 have lasted 5 years or so.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019? (actually 2022) RV-10 N46BX
Old 05-13-2023, 01:00 AM
ScottSchmidt's Avatar
ScottSchmidt ScottSchmidt is offline
Super Moderator
Default It Shrunk
Like others have said, it has shrunk and needs to be replaced.
You be surprised how much it has changed shape when you get the new one.
Once you look at it again you will also see how much it has shrunk in diameter. I just replaced mine again this annual.
I think this is the part number for the Tempest brand rather than K&N.
https://www.aircraftspruce.com/catal...s_08-17580.php
Scott Schmidt
Salt Lake City, UT
RV-10 N104XP (1380 Hours)
RV-12 N321UT (Sold)
