w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 12-13-2009, 10:32 PM
SHORTRV7 SHORTRV7 is offline
Default Elevator balance separate or together
Paint complete on Elevators. How would be the best way to balance the elevators, one at a time or conected together? Or even conected together with the control stick hooked up????
Don Short
RV-7 N-1948P Flying Since 4/2010
Superior XP IO-360
RV-10 Flying since 4/15/22
Barrett IO-540 CAS
Donation Paid
Old 12-14-2009, 05:32 AM
Kevin Horton's Avatar
Kevin Horton Kevin Horton is offline
It depends on your definition of "best". If by "best", you mean which balancing process gives the highest airspeed at which flutter would occur, then you should balance the elevators one at a time.
But, most builders balance them as a unit, connected together, and the service history clearly shows that this is completely adequate as long as you respect Van's VNE numbers. If you ever have an inadvertent high airspeed event, balancing the elevators one at a time will give you a bit more flutter margin.
Kevin Horton
RV-8 (Sold)
Green Bay, WI, USA
http://www.kilohotel.com/rv8/
Old 12-14-2009, 11:18 AM
Bavafa Bavafa is online now
Each individually and definitely not connected to the push rod.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - Out of Paint shop & flying
Dues paid
Old 05-12-2023, 09:45 AM
DeltaTango42 DeltaTango42 is offline
I know this is an old thread, but I have a similar question. I balanced the elevators of my RV9A without any controls attached - pretty well, I think. But when I hook up the elevator pushrod, the system consistently drifts a bit to the "up elevator" orientation. Is this OK ?
Old 05-12-2023, 10:27 AM
Tommy123 Tommy123 is offline
If it balances without the pushrod connected you are good. You balance the control surface, not the system.
Old 05-13-2023, 01:01 PM
motodave motodave is offline
Mine does the same in the hangar... For me the left was heavy and the right was light but when linked together they balanced nicely. I asked Van's about this and they want each to balance separately so I adjusted mine.
Dave
RV7 Slider N732DH Flying!
YIO-360-EXP Thunderbolt
Garmin G3X panel w/VPX
Littleton, CO & KCFO (aka CO Air and Space Port)
Photo log: https://flic.kr/ps/9jjZz
