Go Back   VAF Forums > Model Specific > RV-6/6A
  #11
Old 01-15-2022, 11:58 AM
blaplante blaplante is offline
Or the builder skipped that step.
RV6A in phase 2 as of April 2016
Donation made Oct 2021
Old 01-15-2022, 12:10 PM
There were no alignment holes in the plans when I built my wings (circa '97).
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 01-15-2022, 12:42 PM
664781 664781 is offline
Default Rigging
See manual page 7-40 and drawing 19 for rigging and bellcrank assembly.
Kurt Lohmueller A&P, DAR
Powder Springs, Ga
RV6A "Kurt's Toy" - Flying
RV12 - Flying - Sold
Old 01-15-2022, 01:30 PM
gasman gasman is offline
Alignment holes and pins were used to lock each bellcrank into position during rigging.
VAF #897 Warren Moretti
2021 =VAF= Dues PAID
Old 01-15-2022, 01:37 PM
More info.....
Name:	set aileron.PNG
Old 01-15-2022, 01:51 PM
Another snip from section 15..
Old 01-15-2022, 08:07 PM
jdeas's Avatar
jdeas jdeas is offline
Default just what i needed
Thanks Gasman!
That should allow me to make some progress this weekend.
JD
RV-7 N314SY (KWHP)
IO-360-B1B
A&P
CANbus based trim/flaps and electrical
Old 01-15-2022, 08:26 PM
Mel's Avatar
Mel Mel is offline
Just to reiterate, there were no holes and alignment pins in the early RV-6 plans.
That procedure came later.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 01-15-2022, 11:07 PM
Yes, but it can be used anytime....
Old 01-16-2022, 07:45 AM
WenEng WenEng is offline
Default Neutral Aileron Bellcrank
A simple explanation which worked for me is that you make your own #40 hole in the bellcrank and the angle above it to pin it in neutral position. You know neutral bell crank because the plans show you when in neutral, the measurement from the bearing hole in the bell crank ( that goes to the control stick) is 1 3/16 inches from the vertical surface of the mounting angle. All your bearing adjustments happen after you start with the neutral bell crank, pinned with a 6 inch #40 drill bit after you drill it through both pieces. Then you can always have a neutral position to use forever and ever and ever
Wendell VAF#1832
RV-6A 3/4 done...N48JE Reserved
Build site: www.mykitlog.com/weneng
Donated to VAF in 2021
