Keep VAF
Going
12-19-2018, 10:45 AM
VAF Forum Search help
I can't find a clear answer to my question about searching the VAF database.
Is there any way to perform a "multi-word" search within the forum? Often times I find the search results for a single word to be overwhelming with so many results, that I'd like to search multiple words or phrases to narrow the results down.
Any insights on if (and how) this can be done?
Randy Vanstory
Flying RV10 - N783V
2021 Sun N Fun Reserve Grand Champion
2021 Oshkosh Bronze Lindy
1st Flight 08/20/2020 / Current Hrs - 334
Donation Happily Made 2022
12-19-2018, 10:55 AM
Randy,
If you go to "Today's Posts," then to "Search Forums" (top left). Just enter the multiple "key words" into the space on the top left of the search box. It will indeed search for all words listed.. Hope this helps.
12-19-2018, 11:09 AM
Forum Peruser
Add a "+" sign to search multiple words
Another way to the same search box is Click on the "Search" link in the banner (3rd from the right).
Then click on the "Advanced Search" link in the bottom of the "Search" window...you should then see the same search box/window as you get doing it the other way.
Either way should work.
To answer the main part of your question, "...I'd like to search multiple words or phrases to narrow the results down.
Any insights on if (and how) this can be done?"
If you insert a "+" sign between the words you should get only posts (or thread titles, your choice) with both words in the post (or thread title).
And...if you want either word, just leave a blank between the words.
Hope this answers your question.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
12-19-2018, 11:44 AM
I almost never us the VAF search function.
Using the advanced google search function is far superior for me
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Sliding canopy mostly completed 10/2020
Wiring and Avionics harness completed 9/2/2021
FWF Started 9/3/2021
Donated for 2022 and so should you
12-19-2018, 12:20 PM
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
12-19-2018, 12:32 PM
- or -
use the google search page and do
<search terms> site:vansairforce.com
e.g., this morning I was interested in the term "mogas"
mogas site:vansairforce.com
Axdditionally, you may find the hits include items you don't want. You can remove "hits" that contain words / phrases you are not interested like so:
mogas site:vansairforce.com -injection
-or-
mogas site:vansairforce.com -"fuel injection"
to exclude hits with a word / phrase. Similarly, a plus sign can be used to signal a hit must include that word / phrase.
12-19-2018, 12:33 PM
+1 for Google's advanced search . . . Makes it really easy to create variations of the search terms to filter results.
David Lewis
N647X
RV-7A, KWHP
12-19-2018, 12:52 PM
I find the internal search feature on VAF the best of any forum on the web and I use it almost every day. If you type in Lycoming or propeller, obviously you'll end up with thousands of results as you would with any other type of search. Never had any reason to use some external search engine.
Narrow things down by using multiple words like you would in any other web search- RV-10 doors or fuel tanks for instance. You can also search within a thread and that works great too.
The VAF search returns only words and phrases you actually typed, unlike some other search engines which seem to find unrelated stuff as well.
All this being said, this is a huge site with likely millions of posts by now. On common subjects, you'll get a lot of hits which you'll have to weed through a bit. The more specific you are, the less weeding.
12-19-2018, 02:20 PM
Senior Curmudgeon
Also, in the next block down "Search Options" you may need to reset the "Find Posts From" dropdown menu to better define your search time frame. The default is one year or newer. If you are not sure about when the item you are looking for was posted, change to "Any Date".
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
12-19-2018, 05:49 PM
These search tips/hints are very useful ...
... perhaps worthy of a sticky ??
Vans RV6 flying
SZD 48-2 sold
2018, 19, 20 Dues paid
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
