Old 06-30-2022, 05:54 PM
RicoB's Avatar
RicoB RicoB is offline
Lightbulb Brake disc thickness on RV9a
I got a question, since I can make it to my hangar for couple of days would anyone know the thickness of the standard RV9a disk rotor?
The reason I ask is because I got my hands on a set of grove calipers (2 pistons) model number 31-2M I was told that it requires a 1/4” disk. I currently have Cleveland/Parker 30-9 but I can’t find any info about what disk thickness it uses 1/4” or 0.182”?
I was hoping to be able to just drop the grove calipers in.
Rico Burgos
2018- RV9a at AZ82 and KWHP
1959- C-150 at KMOD (Sold)
https://www.imdb.com/name/nm3018529
2022 dues PAID
Old 06-30-2022, 08:46 PM
bhester's Avatar
bhester bhester is offline
Default This might help, maybe not!
My RV7A wheels, tires and brakes:
Cleveland wheel 5.00-5 PN: 40-78B
Brake disk PN: 164-17
Min. thickness 0.167” / 4.242 mm
Rapco brake disk: RA164-01700
Brake puck o-ring AN6227B-23
Brake Pads: Repco 06-00651
Tire: AirHawk 5.00-5 6ply
Tube: Aero Classic Leakguard
You should be able to find the disk thickness on Cleveland’s site.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2021 VAF donator - alot better than any magazine subscription
Old 07-01-2022, 01:16 AM
RicoB's Avatar
i am sure the 9 is just like that. it won't be the 1/4" thick disks.
Rico Burgos
2022 dues PAID
Old 07-01-2022, 02:17 AM
PaulvS's Avatar
PaulvS PaulvS is offline
Default 9A disk thickness
I've helped put new tires on our -9A and the brake disks are definitely not 1/4" thick, they are thinner, even accounting for wear.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, fuselage almost done, working on canopy.
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
Old 07-01-2022, 07:34 AM
9GT's Avatar
9GT 9GT is offline
You can easily “upgrade” the standard discs to the thicker ones. Off hand I don’t have the part numbers in front of me but I did it on my -9A. My concerns were overheating and warping the standard discs. Somewhere on the forum is a thread or two that includes part numbers if you are so inclined.
David C.
Howell, MI
RV-10: #41686 Under Construction/Sold 2021
"Donor Exempt" but donated through Dec. 2021
Old 07-01-2022, 08:06 AM
Flying Canuck Flying Canuck is offline
I did the Matco high energy upgrade on my 9A a couple of years ago. I believe they are 0.17" minimum thickness rather than 0.13", but don't quote me. I know the OP has different brakes. This is the best single upgrade I've done on the plane, I went from having frequent overheating to the point of having to add lots of power to taxi after a short stop landing, to having plenty of brake and no overheating whatsoever.
Claude Pitre
RV-9A #91081, C-GCPT
Dynon SkyView HDX, IO-320 and WW 200RV C/S. Flying as of August 6, 2018
Added GPS 175 and authorized for IFR April 1, 2021
Interactive map of all of my flights here
Old 07-01-2022, 09:33 AM
RicoB's Avatar
Yeah I will do the upgrade for sure. I am getting the full grove brake kit from a friend ( calipers, masters, parking valve, ss hoses, except the disks) the system was using DOT4 brake fluid. I will be changing all the O rings over to 5606 Compatible. Not sure about the hoses if I can clean them off and re-use it . At the moment I wasn’t planning on changing it all over yet. I just wanted to install the caliper but seems that I will have to get the thicker disk.
Rico Burgos
2022 dues PAID
Old 07-01-2022, 09:37 AM
BillL BillL is offline
Just a reminder to consider the effects of additional thickness of the disc. Like caliper spread (add spacers), clearance from disc to pants bracket, and trimming the axle nut. SCARD did a good post about this back pre 2017. Good luck finding it.
Bill
RV-7
Old 07-02-2022, 05:37 AM
GeoffP's Avatar
GeoffP GeoffP is offline
3/16" .187 new
RV-9, Empennage and Wings done minus fibreglass, Fuselage 50% or more, finishing kits and engine taking up space.
