Hi gang,
I'm having a problem finding a heliocoil for a crankshaft I need to change from 1/2"X20 and reduce to 5/16"X24 thread.
can anyone point me in the right direction to source this?
its for the crankshaft gear, I want to avoid enlarging the crankshaft gear hole.
Do you know where to find a reducer?
Hi gang,
the original engine is a 0-360-A1F6 "D" I sent case to divco to change out to a A1F6, in other words switching from a single dual mag to 2 single mags. the crank is original and was yellow tagged by aircraft specialties, the original crank has a 1/2-20 thread for the original gear hence my dilemma. I didn't realize the bolt issue until after assembly.
