Old 11-24-2020, 12:31 PM
LCampbell LCampbell is offline
Default Trailing Edge Wedge Protusion Question
I'm just finishing my ailerons on my RV-10, and so far they are tuning out great, however I have a question...
I know that the exact point of the trailing edge can have an effect on the control surface's behavior, but am not clear on what causes what.
I seem to have on both of them a thin bit of the wedge that sticks out a bit further than both the top and bottom skins the same amount. I know I didn't take that much off when deburring the skins, and besides, it's exactly consistent the entire length.
Would you:
1. Run a file along the protruding edge to even it up?
2. Know that paint will make it a non issue?
3. Be prepared for wild and bizarre roll sensitivity?
4. Ignore it, build on, and spend more brain cells contemplating deserts for the upcoming holiday?
Any thoughts welcome,
Lance
Old 11-24-2020, 01:37 PM
wirejock's Avatar
wirejock wirejock is offline
Default Wedge
I would ask Vans before removing material. I've seen some stuff on the 10 and 14 I thought looked odd but Vans designed it that way.
Seems like a sharp edge is preferable to a wide curve?
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Disclaimer
Old 11-24-2020, 01:42 PM
Steve Melton's Avatar
that trailing edge looks good to me. looks same as the -9. nice workmanship.
Steve Melton
Cincinnati, OH
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 11-24-2020, 01:51 PM
rvbuilder2002's Avatar
The protruding amount of AEX wedge is designed in on purpose.
Scott McDaniels
Hubbard, Oregon
Old 11-24-2020, 01:55 PM
terrye terrye is offline
I filed all of my trailing edge wedge protrusions flush with the top and bottom skins. I think the control surface sensitivity comes mostly from the RV-6 type ailerons where there is a rounded trailing edge. This can result in unstable (oscillating from top and then bottom) vorticies. Many aerobatic planes have a really large square trailing edge to eliminate this, as does the RV-14 elevator. If in doubt, discuss with Vans.
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 11-24-2020, 02:18 PM
PilotjohnS PilotjohnS is offline
Default Just me
I tried to eliminate this AEX edge sticking out, but the double flush rivet heads would then touch and come out poor. So I left the AEX wedge stick out like you have it. After the proseal dried for a week, I took a file and made a blunt edge by filing the AEX wedge down to the skin edge. Came out really nice.
John S
Dues paid 2021, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Electrical 35% in work
Firewall Forward 5% in work
Fiberglass 0%, thought i was building in metal?
Old 11-24-2020, 02:34 PM
scsmith scsmith is online now
Scott, I am curious about the rationale for leaving the extrusion protruding?
I would be inclined to file it flat and square. This would create a small base to the trailing edge that has lower hinge moment than a sharp trailing edge, but a little higher drag. (lower hinge moment means lighter stick forces)
But the step shape of the trailing edge with the two skin steps to the sharp extrusion probably has similar drag to the squared off base, and I don't think it will provide any hinge moment reduction.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 635
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2020
