Old 11-28-2011, 09:39 PM
lostpilot28's Avatar
lostpilot28 lostpilot28 is offline
Default Help with measuring cowl pressure differential
I didn't give this much thought before I purchased a vacuum/pressure gauge. It's one of those single port devices that measures negative or positive pressure from 0 to 10 psi or 0 to 30 in/Hg. Exact model is here.
My plan was to place tubes at various locations under the cowl to read the pressure at that specific spot. I could run several lines, label them, then swap the gauge to a different hose in the cockpit while flying. But, I'm not sure if this instrument is going to work. Maybe it will....it just seems to need a pretty good amount of suction to move the dial, and I'm not convinced I'll be able to read that much variation under the cowl.
What do you guys think? I really don't want to build a manometer for inside the cockpit, so the dial idea was ideal. Any help is greatly appreciated.
Sonny W
Boise, Idaho
RV-7A Flying!
Old 11-28-2011, 09:59 PM
rocketbob's Avatar
Not going to work because thats an absolute pressure gauge.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 11-28-2011, 10:23 PM
DanH's Avatar
DanH DanH is offline
Nor is it sensitive enough....1 inch Hg is 13.596 inches of water. Differential pressures under the cowl are often just a few inches of water. Heck, 100% dynamic pressure at 200 knots and sea level isn't quite 2" Hg and less than 1 psi.
Dan Horton
RV-8 SS
Barrett IO-390
Old 11-28-2011, 10:47 PM
Thanks guys...once I got it I sort of realized it wouldn't be sensitive enough. But, Bob, what do you mean about it being "absolute"? Couldn't I use a (more sensitive) gauge to measure the absolute pressure at various locations under the cowl, then compare the results?
Sonny W
Boise, Idaho
RV-7A Flying!
Old 11-28-2011, 10:53 PM
rocketbob's Avatar
Actually its gauge pressure, not absolute pressure. Gauge pressure means one side of the gauge is vented to ambient. And unless the gauge (if it were sensitive enough) would have to be in the area you are comparing for it to have a meaningful reading.
What you need is a differential pressure gauge that is sensitive enough. Something like a Dwyer Magnahelic.
N8155F C150 flying
Old 11-28-2011, 10:54 PM
Phil's Avatar
Phil Phil is offline
I'm guessing something like this is the right thing???
http://www.transcat.com/Catalog/prod...tm_medium=base
I think the difference is measuring relative (AKA: differential pressures) vs absolute pressures (not relative differentials). I don't know, but I'm just guessing that's the idea since this device measures differential.
I might snag one if it's the right tool. It sounds like something that could be worthwhile and save a whole lot of frustration.
Phil
Old 11-28-2011, 11:15 PM
Absolute pressure is zero-referenced against a perfect vacuum, so it is equal to gauge pressure plus atmospheric pressure.
Gauge pressure is zero-referenced against ambient air pressure, so it is equal to absolute pressure minus atmospheric pressure. Negative signs are usually omitted.
Differential pressure is the difference in pressure between two points.
So, why can't I use Absolute or Gauge pressure and read either at various locations under the cowl? That would provide the data I need. I really don't care about the values as much as I care about point A being higher/lower than point b, c, d, and e. If I'm just getting a number at each location, wouldn't I know how air is flowing in and out of my cowl?
Sorry for my ignorance...just trying to find an easy solution that I don't have to "re-rig" for several different test flights. And, I don't want to pay $200+ for an instrument (sorry Phil ).
Sonny W
Boise, Idaho
RV-7A Flying!
Old 11-28-2011, 11:22 PM
Phil's Avatar
Yeah, I hear ya.
I just wrote the check for a new IO-540. So from the new IO-540 perspective, $200 is a really cheap way to get some really helpful data.
I agree it's painful, but I don't want to sink any more money into engine repairs when I could just take care of the really expensive one I own today. So I don't mind paying an extra $200.
On a side note:
$200 is pretty easy to make up in fuel when comparing a trial and error approach with using instruments to collect exact data. It's probably close to a wash.
Old 11-29-2011, 12:07 AM
CMW CMW is offline
Default Digital manometer on Ebay
There are a bunch of new digital manometers on Ebay for $37. +/-2psi range. Here's a link.
http://www.ebay.com/itm/Digital-Mano...ht_4657wt_1010
-Chris
Chris
RV-8 Wings
Old 11-29-2011, 12:18 AM
Phil's Avatar
Very cool. For 37 bucks, I can wait for it to come from Hong Kong!
Thanks!
Phil
