Keep VAF
Going
11-27-2011, 09:51 PM
How many pitot's do you need?
When configuring a -7A for IFR with a glass cockpit is seems the wisdom out there dictates to also install some steam gauge backups. If so, then can a single pitot work for the EFIS ADAHRS and the steam gauge? May sound like a dumb question but I have asked several folks... including AP's...and the range of answers is somewhat astounding. What is the input from the VAF crowd?
Steve
Steve
RV-7A, N783RV
Flying since 10/1/2013 Tach: 1450+ hours
Lyc O-360-A1A
11-27-2011, 10:00 PM
I have one pitot feeding an autopilot, steam airspeed, and an AFS3500. There is no flow in the pitot line.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
11-28-2011, 06:05 AM
Yep
Since there really isn't any "flow" but rather pressure, you can use one pitot for multiple points.
My -10 has it to a D-100, a standby AS and the TruTrak autopilot.
Best,
Rv10 Sold
46 years ag pilot/CFI
Air Tractor 502/PT-6
Building RV-12, Wings, fuse, emp complete. FWF in progress.
11-28-2011, 08:09 AM
VAF Moderator / Line Boy
For my IFR aircraft, I use a single Pitot (been flying that way for decades in spam cans...). Pitot heat should take care of ice (although I flight plan to avoid evene the potential of icing, or I don't go!) - you are susceptable to a perfectly aimed bug of course. I personally consider that a low risk.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
11-28-2011, 08:35 AM
Just my opinion as a not yet pilot or aircraft owner but it seems the most likely item to cause a failure of the airspeed/altimeter indications would be leaks or clogging of the pitot/static probes and lines. I would see nothing wrong with separate systems.
Joe Mikus
MSgt USAF Ret Avionics Tech
Perryville, MD
Student Sport Pilot
Future RV-12 Builder?
11-28-2011, 08:57 AM
One for each pilot on-board.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
11-28-2011, 09:12 AM
Sid Stole It...
I quickly read through the thread title and I though it said, "How many pilots do you need?"
That sounds like the entry line for any number of crude jokes. Especially around fighter pilots.
Jay Staub
Lt. Col., USAF, Ret.
N6565S Reserved
11-28-2011, 09:32 AM
Put 2 pitots in and you'll always wonder which one's right. Small chance they'll both read exactly the same.
Kind of like asking a guy with 2 watches what time it is.
Kurt W.
RV9A
FLYING!!!
11-28-2011, 09:57 AM
Originally Posted by Ironflight
....you are susceptable to a perfectly aimed bug of course. I personally consider that a low risk.
If you don't use a pitot cover on the ground, there's a much higher chance for a clogged pitot due to a bug. Happened to me once.
Now I use one of those flip-up-in-the-wind covers, test it on preflight, and in the next 1,400 hours of mostly rural airports, have had no problems and no cover malfunctions.
Here's a link to one:
http://www.aircraftspruce.com/catalo...eprotector.php
The only issue with these is that they pop open during the take-off roll and the airspeed needle swings wildly for a second right when you'd like to have it work. As a result my take-offs are by feel. And before lift-off everything's fine. The gadget is recommended.
Dave
11-28-2011, 02:05 PM
I read it correctly but my first thought was, 'It depends on how many airplanes you own.' I prefer having one pitot for every plane I own. Right now I have two pitot tubes but I might need a third on soon<g>...but the wife doesn't share my opinion...yet.
Don Alexander
Virginia
RV-9A 257SW Purchase Flying - O-320, Dynon D100
RV-9A 702DA (reserved) Finish Kit IOX-340
www.propjock.com
Thread Tools |
Display Modes |
