Old 06-29-2020, 04:16 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default impressive!
Great work Pete - whatever you are doing, keep doing it! Do you feel that the cleanliness of your valves is due to running unleaded fuel? Did you ever get around to the oil analysis? What kind of oil do you run? Any additives?
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 06-29-2020, 06:02 PM
tthrew tthrew is online now
Default Oil consumption?
Hi Pete - what is your oil consumption and what level are you running? Oil separator? Thanks
Tim
RV-7A N54LH O360 CS 1200+ Hobbs
Joined VAF 2015
2020 VAF dues Paid
Old 06-29-2020, 08:39 PM
petehowell's Avatar
Default Mogas....
Hi Mickey,
I do think that mogas keeps things cleaner, but I think it is observational and can't quantify it.
Sadly I forgot to buy the oil analysis kit. Maybe next time.
I have only run Phillips XC 20W-50 from hour zero. It has worked well for me.
Pete
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 06-29-2020, 08:48 PM
100 only hours in 10 months Pete? Head my way lets go backcountry
Old 06-29-2020, 08:51 PM
petehowell's Avatar
Default 5Qts
Hi Tim,
I have been running 5 qts since about hour 100. Any more just blows out the breather very quickly - I do not run an oil separator.
I use about 1-2 qt per 50 hours, it has been that way since she broke in. I usually need about 1/2 qt at 25 hours and 1/2 qt at 35 or 40. I just keep it at the 5 qt line on my dipstick. My guess is the viscosity improvers start to breakdown, but I am no petro chemist. I'm sure there is someone here that can explain it.
Pete
St. Paul, MN
Old 06-29-2020, 10:11 PM
petehowell's Avatar
Default we tried!
Vlad,
We were headed to Idaho - but the wx this week was not tent camping friendly and work got in the way. We have another window in August.
Pete
St. Paul, MN
Old 06-30-2020, 08:58 AM
von_flyer von_flyer is offline
Curious how your plugs look.
John von Linsowe
Michigan
RV-7
Cessna 140
Old 06-30-2020, 10:11 AM
turbo's Avatar
turbo turbo is offline
have you ever done any measurements on wobble test?
TURBO YES =VAF= Payed Jan2021
Ed D'Arcy
RV6-A 5,200+ hrs, R-44 1,600 hrs, Helicycle traded for 33 FFR coupe, gyro sold,35,000 miles flown in 2015
addicted pickle ball player
Old 08-17-2020, 10:23 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Heya Pete -
I hesitate to call it a full blown separator - it's more of a breather - but it lets me run 8qts without putting anything on the belly and best of all I put it together in an afternoon with metal I had leftover from the build (recognize part of a trimmed push tube? :-) Happy to share more if you'd be interested.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
