Old 06-29-2021, 06:20 PM
David Z David Z is offline
I completely agree. -39c is easier to accomodate than +39c. Just put on a warmer coat, plug in the engines and keep working. Not sure what to do when it's too hot....
RV8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage assembly, it's a riveting job!
83126
Dash 8 day job is financing the RV8
Donation till September 2022
Old 06-30-2021, 09:17 AM
abwaldal@gmail.com abwaldal@gmail.com is offline
Default Heat?
I have the solution for the heat. Seems the guy who had my hangar before I was lucky enough to be in the right place at the right time. Installed a 5 ton heat pump system.
Yes I have an airconditioned hangar.
I insulated the living bejeebers out of it, sheet rocked, sealed every air leak I could find, and painted and never looked back.
Outside 105 degrees and a nice comfy 75 degrees inside where I'm working.
Reverse in winter. Slab almost guarantees 52 degrees unless I turn on heat.
Suffering for sure??? Ha Ha Ha
Art
How's that for off thread??
Last edited by abwaldal@gmail.com : 06-30-2021 at 09:19 AM. Reason: needed more info
Old 06-30-2021, 09:07 PM
What are the min and max operating and storage temperatures for the SDS systems? I often see +60c to -40c on other electronics.
RV8
Wings mostly done
83126
Old 07-01-2021, 06:54 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Operating temps for the latest displays is -20C to +70C. The characters become slow to resolve below -20C however in our testing, still reasonably visible down to about -28C.
The ECUs have been run down to -44C and up to +52C ambient. Sun soaked electronics can reach 70C under the higher ambient conditions. We've bench run ECUs to this temperature after baking them for an hour in the toaster oven.
Most sensors and modules are rated to 125C.
Storage temps, well never really tested to extremes but I don't see why they would be damaged by any reasonable temps, say -50C to +80C.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 456.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
https://www.youtube.com/channel/UCiy...g2GvQfelECCGoQ
Old 07-01-2021, 06:56 AM
rv6ejguy's Avatar
Default Closed Today for Canada Day
We're still in the record heat wave here and will be closed today for Canada day. Open again on Friday.
Old 07-18-2021, 09:54 PM
rv6ejguy's Avatar
Default Deliveries
Our order backlog continues to grow despite our best efforts to keep up. We're now at 8-10 weeks on CPI-2 and EM-5 kits. 1-2 on most CNC'd parts and CPIs.
We'll put your order in sequence and give you a call or email when we are about ready to commence building your kit.
We've experienced a few shortages and backlogs from some suppliers. Have managed to find alternate sources so far and hoarded some of these even if the costs are higher. Unfortunately aluminum prices have climbed 10-25% in the last 6 months of so. That will eventually lead to some slight price increases for some of our bits.
A word of caution to customers: If you disassemble mechanical components for any reason, be sure to note any fasteners or parts which are Locktited and use it again on re-assembly. Some people didn't and have had stuff come loose. If you're not sure what to use, give us a call or email.
We're working on some new parts and improvements to be released soon.
Old 07-23-2021, 08:26 AM
rv6ejguy's Avatar
Default Oshkosh
We won't be at Oshkosh this year but will have some folks there with SDS products.
A just saw Les Kearney take off here with his RV-10 you've seen in several videos. He's happy to show you his EFI installation and talk about it. PM me if you want his number to meet up.
Ray Ward will be at the Team Rocket booth with his F4 and CPI-2. He has a limited supply of SDS swag.
Two time Reno Sport Class winner Andy Findlay may be there from Sunday to Tuesday with his SDS equipped Super Legacy.
Marvin McGraw should be there with his RV-14 as well.
I believe Dave Anders will be doing the Cup Race this year.
To all those going to Osh this year, have a great time!
Old 07-25-2021, 08:24 AM
rv6ejguy's Avatar
Marvin's RV-14 is parked in HBC, row 314 for those interested. N829MS.
Les Kearney's RV-10 is in row 345. C-GROK. I have Les' number if you want to meet up.
Kyle Fowler will be performing in his Long-EZ with SDS EFI again. He's also happy to talk about our EFI with you.
Old 07-25-2021, 01:02 PM
For those with a RV14 that want to see the cabin install parts, come to the AS Flightlines booth 948. Its in the ultralight area. We have our RV14 cabin mockup on display with the SDS pump, Andair Duplex valve, our wing root filters, and the cabin Beringer brake system. Alittle bit of a hike, or a tram ride, but you can get an up close and personal look at how it all installs.
Steve and I will be there all week.
Tom
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
Old 07-27-2021, 10:15 AM
rv6ejguy's Avatar
Default Cup Race
Dave Anders took top spot in RV Gold at 241.25 mph.
