Old 10-14-2021, 02:44 PM
ajay ajay is offline
Default Alternative R10 Engine
Anyone looking at the Continental CD-300 turbocharged Diesel, FADEC controlled burns jet fuel with 300 hp.
Old 10-14-2021, 02:52 PM
Auburntsts's Avatar
What’s it cost and weigh?
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
DanH's Avatar
DanH DanH is offline
Doesn't matter. I've not been tracking things like I was, but I doubt you can buy one.
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-14-2021, 04:05 PM
Default ...and
Might want to talk to the guy with the CD-230(?) that he had on his -10...
Bob
Aerospace Engineer '88
RV-10-ER
N464RL
Going to Paint at Evoke!
Garmin G3X-T, Barrett EFII S32, CAI, MTV-9B
Dues+ Paid 2021,...Thanks DR+
Old 10-14-2021, 04:46 PM
KMMUflyer KMMUflyer is online now
Default CD155 DIESEL
Not to derail the discussion...
Apples to Pears comparison.
I saw a current ad for a prop strike 2015 CONTINENTAL CD155 DIESEL
The photos didn't look pretty. Not sure if it speaks to the severity of the prop strike, the fragility of the design, or neither.
Chuck
Old 10-14-2021, 09:52 PM
I’m just curious. It’s the engine on the Diamond DA50RG, something it took them years to decide on.
Here’s the spec sheet
http://www.continental.aero/diesel/engines/cd300.aspx
The performance at altitude is impressive and cruises at 9 Gal/hr, but the dry weight is 584lb ( I assume with all accessories, and also doesn’t include coolant ). Isn’t that 130lb heavier than a similarly equipped IO540?
Old 10-15-2021, 05:17 AM
Auburntsts's Avatar
Yeah it's at least over 100lbs heavier than a 540 - that's a huge problem. I'm betting it's significantly more expensive than a new 540 too.. As a result, I thinking that for most the juice simply wouldn't be worth the squeeze.
PP ASEL-IA
WAR EAGLE!
Old 10-15-2021, 06:40 AM
airguy's Avatar
airguy airguy is offline
As Dan said, it doesn't matter. Continental won't sell them to the experimental market. I've been trying for years.
Garden City, TX VAF 2022 dues paid
N16GN flying 1,000 hrs and counting on 91E10; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Pending Repeat Offender - 10 kit is on order. TDI? Turbine? Stay tuned!
Old 10-15-2021, 06:46 PM
David Z David Z is offline
Rough napkin math here, comparing to a similar gasoline engine like the -540. The diesel is burning 10lbs/hr less fuel (9gal/hr @ 6.7lbs/gal diesel versus 12gal/hr @ 6.0gal/hr gasoline). For an engine that's 100lbs heavier, the flight time for break even payload capacity is 10 hours!
RV8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage assembly, it's a riveting job!
83126
Dash 8 day job is financing the RV8
Donation till September 2022
Old 10-15-2021, 08:03 PM
TS Flightlines TS Flightlines is online now
Go ahead---if you can find one. Eat lunch first, 'cause you be doing ALL of your own engineering, and fabricating everything.
So unless you are an excellent welder, fiberglass/carbon fiber guy, aluminum fabricator, and an aeronautical engineer that can figure all of this out-----
you might rethink it. Yep sounds fabulous, but probably not practical.
Tom
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
